Valve clearance?
r1150rr
Valve clearance?
Post by r1150rr »
Is the rockster valve clearance 0.06 and 0.012? ie the same as a r1000.
thenewcamus
Post by thenewcamus »
nope .15 and .30 respectively
check this thread:
http://r1150r.org/board/viewtopic.php?t ... ht=015+030
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Your numbers are correct for inches clearance (moving the decimal appropriately, of course). The reply numbers are the mm measures.
