Lowering the Rockster
Posted: Thu Jul 27, 2006 8:08 pm
Has anyone lowered their Rockster without adverse effect?
Thanks!
Thanks!
Welcome to r1150r.net, your largest online source for all things R-R!
https://r1150r.net/board/
That's what I was thinking, but don't really want shorter springs, as it's bound to change the way the bike rides.DJ Downunder wrote:You could let some air out of the tires...![]()
How low do you want to go?...shorter springs would be the only way to do it..IMO
Searching shows the R and RT arms are the same lenght. so no help there.riceburner wrote:You could TRY a longer Paralever arm - that would change the height of the rear end?
Not sure what bikes have a longer arm though: RT??
(the GS one is 5 mm shorter - but that equates to about 2" of difference in the ride height!!)
Get an adjustable and see if it'll go longer? (I think they will)M1ka wrote:Searching shows the R and RT arms are the same lenght. so no help there.riceburner wrote:You could TRY a longer Paralever arm - that would change the height of the rear end?
