Plug Problems
Posted: Mon May 04, 2020 12:38 pm
So far, I've done two valve lash adjustments - a bit more involved then on an airhead. But hey....I didn't have to remove cam shafts like on my KLR. However, one part of the procedure has driven me bonkers - re-installing the rubberlike plug that lives in the inspection hole. You know, where you view the marks that tell you you're in the right place to adjust. After the first time, I thought the problem was that the plug had hardened. I made sure to have a fresh softer plug the second time around. No better....maybe it was my lack of touch; my brother gave it a try. It took him a full twenty minutes before finally getting the recalcitrant miscreant in.
I supposed that there must be a trick to this. I couldn't imagine wrenches at the dealer taking this much time. So...I asked a respected tech in suburban Chicago what he did. He answered that his solution was to never remove the plug. Instead he turns the engine till the valve train parts can be moved by hand. I did that, but also thought it necessary to look into the hole. He added that he lines up arrows that can be seen on the left side of the head. I don't remember those but I'll investigate next time I'm in there.
What do you guys do ? I don't remember anyone mentioning this since I've been on the forum.
