Autocom removal
Autocom removal
I'm just looking at removing the autocom from my R. It is mounted just in front of the seat, with the feed wire disappearing off under the tank. I thought initially it just went to the battery, but as far as I can see (without removing the tank) it goes off toward the front of the bike. Anyone got an idea where it would be connected? Is there a specific kit for R's or is it just down to the local tech. Should there be an inline fuse there somewhere?
Cheers
Barry
Cheers
Barry
Autocom removal
The Autocom does not come with a specific 12V supply location. Each owner/fitter chooses the location.
It is most likely connected to a switched supply which up the front of the bike includes the park light etc.
Many take the power from a fused source within the fuse panel; for instance, the horn fuse.
If you can't locate the junction, why not cut the cable and insulate the end.
