Some fun takes on the upcomming R1200S
Posted: Fri Nov 18, 2005 12:30 pm
by Deans BMW
Picked from Pelican.
This is too much fun, I plan to be at San Jose when their first R1200S arrives.
[/img]
Posted: Fri Nov 18, 2005 12:39 pm
by Deans BMW
Posted: Fri Nov 18, 2005 12:41 pm
by collyers
that last one looks very Darth-like. Dave? OK, now SECOND to last.
The yellow striped one is much less annoying than the red. Those Germans & their wacky sense of humor - it always come out in design & paint jobs. If they could just hire an Italian designer with a germanic name......
Posted: Fri Nov 18, 2005 1:16 pm
by Deans BMW
I really like this one, the yellow one is OK also.
prep
Posted: Fri Nov 18, 2005 1:38 pm
by ride1150r
I own a 2004 r1100s prep, i'll tell you what, if they offer a prep in the r1200s, the r1100s will be forsale. I'm liking that bike. ALOT!
scott
Posted: Fri Nov 18, 2005 1:51 pm
by Deans BMW
As I posted on another website, "You couldn't spend enough money on a R1100S to get within 80% of what the R1200S is"
San Jose BMW routinely makes 92 to 94 RWHP R1100S's (R1150SJS) for a goodly sum.
The new R1200S will have appx 110 RWHP stock, be a lot lighter, much better tranny, much better brakes, much better handling and a better engine mgmt. system.
Re: Some fun takes on the upcomming R1200S
Posted: Fri Nov 18, 2005 2:02 pm
by Guest
Deans BMW wrote:This is too much fun, I plan to be at San Jose when their first R1200S arrives.
Dean, I'll warn Chris!
Posted: Fri Nov 18, 2005 2:25 pm
by Deans BMW
UH OH, I'm in trouble now.
Posted: Fri Nov 18, 2005 5:12 pm
by new2BMW
I still wanna know the wheelbase Dean. C'mon and tell us.
Posted: Fri Nov 18, 2005 6:26 pm
by scottybooj
i like the last one.
it's like darth but in a swoopy version.
Posted: Fri Nov 18, 2005 6:37 pm
by 9291150
Already it begins. The "much" better everything.
I've been around all types, my favorite was this one guy that I would see at nearly each track day I've been to. Last I saw him he had a 2004 R1 because it was much better than his 2002 R1, which was much better than the 1999 R1 he had. To hear this guy go on about the new advances each time was really something.
Guess what, he was still passed (as was I) in most sessions by the same resident hotshoes on their 80's RZ350's and the like. I'd often get stuck behind him often, I swear he actually got slower with each bike.
I thought beemer types were different, and I still think by and large we are, but everywhere there are the "have the latest and greatest...just because" types. What can you do?
Well, if you think it makes you happy...goodforya
Posted: Fri Nov 18, 2005 6:55 pm
by Deans BMW
This should be the specs on the new S
http://www.bmw-motorrad.com/com/en/index.html
The Wheelbase (in normal position) 1,487 mm
Engine
Type Air/oil-cooled 2-cylinder 4-stroke Boxer engine, one camshaft and four valves per cylinder, central compensation shaft
Bore / stroke 101 mm x 73 mm
Capacity 1,170 ccm
Rated output 90 kW (122 PS) bei 8.250/min
Max. torque 112 Nm bei 6.800/min
Compression ratio 12.5:1
Mixture control / engine management Electronic intake pipe injection/digital engine management: BMW engine management, BMS-K with overrun fuel cut-off, dual ignition
Emission control Closed-loop 3-way catalytic converter
Performance / Consumption
Maximum speed More than 200 km/h
Fuel consumption over 100 km at constant 90 km/h 4.3 l
Fuel consumption over 100 km at constant 120 km/h 5.6 l
Fuel type Unleaded premium, minimum octane rating 98 (ROZ), can also be operated with minimum octane number 95 (RON) due to automatic knock control.
Electrics
Alternator 600 W three-phase alternator
Battery 12 V / 14 Ah
Power transmission
Clutch Single-disc dry clutch, hydraulically operated
Gearbox Constant mesh 6-speed gearbox with helical gearing
Drive Shaft drive
Chassis / Brakes
Frame Three-section frame consisting of front, middle and rear section, load bearing engine-gearbox unit
Front wheel location / suspension BMW Motorrad Telelever;stanchion diameter 41 mm, central spring strut
Rear wheel location / suspension Die-cast aluminium single-sided swinging arm with BMW Motorrad Paralever; WAD strut (travel-related damping), spring pre-load adjustable, rebound damping adjustable
Travel front/rear 110 mm / 120 mm
Castor (in normal position) 87 mm
Steering head angle (in normal position) 66°
Wheels Die-cast aluminium wheels
Rim front 3.50 x 17"
Rim rear 5.50 x 17" (special equipment: 6.0 x 17")
Tyres front 120/70 ZR 17
Tyres rear 180/55 ZR 17 (special equipment: 190/55 ZR 17)
Brake front EVO brake system with dual disc, floating brake discs, 320 mm diameter, four-piston fixed caliper
Brake rear Single disc brake, diameter 265 mm, double-piston floating caliper
ABS Special equipment BMW Motorrad ABS, disengageable
Dimensions / Weights
Length 2,151 mm
Width (inc. mirrors) 870 mm
Height (not inc. mirrors) 1,177 mm
Seat height, unladen weight 830 mm
Unladen weight, road ready, fully fuelled 1) 213 kg
Dry weight 2) 190 kg
Permitted total weight 410 kg
Payload (with standard equipment) 197 kg
Usable tank volume 17.0 l
Reserve Approx. 4.0 l
1) According to guideline 93/93/EWG with all fluids, fuelled with at least 90% of usable tank volume
2) Unladen weight without fluids
Posted: Fri Nov 18, 2005 9:13 pm
by JCsman
Posted: Fri Nov 18, 2005 10:04 pm
by socalrob
I like the standard yellow weve seen in some pixs.
That last one with the all black & a bit of red looks good, but I've been thinking the yellow is more visible & standard & cheaper. All around a good deal.
Seeing how good the S looks, I'm really looking forward to seeing the new R1200R. I'm hoping for sub 500lbs wet with ABS & sleek looks more to the S style than the ST.
One can hope.
Posted: Sat Nov 19, 2005 11:49 am
by Deans BMW
There is a photo shop expert over at Pelican.
Posted: Sun Nov 20, 2005 2:40 pm
by bmwdave52
For some reason these bikes remind me of a wasp.
