Came across this 2004 BMW R1150R with 28K miles on it. My mind was like
Rides smoothly although there is a noticeable vibration when idling and starting from a stop. It smooths out pretty good around 3500rpms and I can cruise at that all day without a problem. However, at around 4000-4500rpms they come back...although not nearly as noticeable at pickup from a stop. Is this normal??
I have noticed some oil leakage on the right fork so might have to check that out. Hoping for just dust in the seal.
I had trouble getting it in 3rd when doing the test ride but a little lube in the shift links fixed that.
Anywhere I can find the electronic version of the manual? I saw links around the forum for the AScyles but it errors out.
What are the oil change frequencies and types? Looks like this bike uses all kinds of different oils for the engine, tranny and final drive.
Thanks in advance for your help.
