Battery (/electrical) Diagnosis
Posted: Mon Sep 05, 2016 4:07 pm
Been trying to gauge whether Im due for a new battery or not on my Rockster. I'll point out that I'm good mechanically, not really good electrically, but am feeling like I am starting to get it.
a bit of history - I had a non-start a bit back, towed to my house and am trying to complete the repair myself, so I have better understanding of my bike… the tank is off, and have been trying to follow the Climber manual for diagnosing.. But not quite sure I'm doing it correctly:
When first took the tank off, I put the battery on a tender and checked the terminal connections. They felt fine, but I did tighten them a bit, though I don't think it changed anything. I did notice that the fuse (7.5A) in the tender lead had blown, which is something I'd noticed a while ago. So replaced that fuse, but not really sure why that would blow. I had fiddled with the heated grips a while back, so I might have caused that.
Anyway, I brought it up to float and tried to start it - without the tank on - it tried to turn over, but struggled. I put the tank on and it struggled less, then I re-connected the tender (via the sae pigtail) and it did start, but wouldn't stay running w/o the throttle open. I didn't ride around because I only partially put the tank back on (didn't reconnect anything else). I just wanted to see what it would do with some gas available.
So the tank is back off - without the tender connected, the battery reads 12.68V, which is below what the Climber manual says is low charge (says it should be above 13V). And with the tender connected, it reads about 14.4V.
I did a parasitic draw test. Well, I should say I attempted that, but when I disconnected the negative terminal, and placed my ammeter in between there's no current at all. I tried this a couple different ways, and nothing would get any reading. If I put a bulb tester between just the terminals on the battery, it lights, and I can get a reading if I place the ammeter into that circuit, but don't get anything by placing it between the negative lead and the negative terminal (and trying this with the light tester does nothing as well).
Does having the tank off and that part of the electrical unplugged affect what I should see? Doesn't seem like it since that is what's described in the climber manual, but like I said, I don't understand the electrical well enough to really know for sure
I have to be doing something wrong, but don't see it… any help would be greatly appreciated.
Dave
Dave
