12-volt switched source
Guest
Post by Guest »
What is a good 12v switched source at the fusebox to run a fused wire to the handlebars for low-draw accessories (GPS, meter, etc.)?
FGanger
Post by FGanger »
A number of people report using the hand warmer. I just run from the battery, or the starter and then use a relay.
Frank
KHaynes
Switched Fuse
Post by KHaynes »
I favor the horn fuse. On my R1150RT and GS, it's number 4 fuse. I expect it's the same on the R1150R.
Keith Haynes
R1150RT
Wheelcaps
Guest
Post by Guest »
Thanks, KH!
