GPS mount
Andrew s
GPS mount
Post by Andrew s »
I'm looking for a GPS mount that fits onto the handlebar clamps on the top yoke, anybody know where I can get one, or the make.
Re: GPS mount
You can probably get a RAM mount - pipe-clamp that should work.
Andrew s
Re: GPS mount
Post by Andrew s »
Cheers Ricey, I did have a mount but sold it, think the one I'm after is a Touratech one.
Fauster
Re: GPS mount
Post by Fauster »
I got a SW Motech mount from Twisted Throttle. The base mounts using the four bar clamp bolts. I'll take some pictures and upload them shortly.
2004 Citrus Green Rockster, 2005 F650GS
Fauster
Re: GPS mount
Post by Fauster »
The base:
The bottom view of the adjustable mount:
Installed using a RAM diamond base and RAM nuvi cradle:
Andrew s
Re: GPS mount
Post by Andrew s »
Thanks for the photos, it is very similar to the one I had, which was fixed the same way but just had a round bar to fix the Satnav cradle.
What Satnav do you use with it?
Fauster
Re: GPS mount
Post by Fauster »
I'm currently using my auto Garmin nuvi 1350 in the cradle. Not waterproof, but I just bring along a clear Zip-Lok bag to cover it. Worked well on a 3700-mile trip last spring on my F650GS. I've only used this mount on the Rockster a few times but I like how I can adjust the angle of the GPS unit for my dingle sight lines.
The mount slides into the raised 'U' on the base and locks securely. A plastic latch is then depressed to slide the mount out from the base. It has some internal dampening and the RAM ball also keeps it from vibrating.
Hawkeye
Re: GPS mount
Post by Hawkeye »
I have a Garmin car gps and just put suck it on the speedo glass. Works well, but I do have a screen and asso have a safty cable on it on the off chance it comes off. The gps gives me my speed.
To easy.
Andrew s
Re: GPS mount
Post by Andrew s »
I've got a Zumo 660, so going to get an SW Motech mount I think.
Anybody use this mount and if so, what's it like.
