R1150R Handlebars
- PhillyScott
- Location: Philadelphia.....and sometimes West Yorkshire, UK
R1150R Handlebars
I'm new to this board, so let me first say hello!
I've been contemplating the purchase of an R1150R and like the bike a lot, but the handlebars are quite a bit different to what I'm used to. Has anyone changed the bars to make them shorter and/or lower? Is there a way to install a high "clip-on" type bar?
Bikes I currently own are:
'93 Moto Guzzi 1000 S
'03 Triumph Speed Four
'05 Triumph Bonneville Thruxton
The R1150R will replace my Triumph Speed 4, as I need at least one bike that will be good "two-up" and allow for panniers.
Moto Guzzi 1000 S
BMW R1150R Rockster
Moto Guzzi V7 'Cafe' Classic (UK)
BMW R1150R Rockster
crousos is right. The rockster bars are an option. I switched my OEM bars to the rockster bars. No mods to wiring or anything else were needed and I'm sure you won't have any trouble selling a used OEM bar. I sold mine in a day.
"Be a man and face the fire. Make something ugly into something beautiful." Unknown taxi driver.
DJ Downunder
Hi there PhillyScott....you're right about the RR..it will be good "two-up" and allow for panniers.
When I got mine almost 4yrs ago the first thing that I wanted to do was put a lower and shorted bar on...maybe even a flat bar.
Now I'm not sure...maybe if you position yourself lower and more forward you will need to move the pegs back a bit also..or it might feel a bit odd.
The rockster bars are a little lower...but also a bit wider...so I gave them a miss.
I ruled a flat bar out because of tank clearance...and also our bars have holes and dents in them I think...for the heated grips.
It first I didn't like the big trail bike feel the stock bars had but I'm used to them now and very happy with them.
I did loosen the mounts and rotate them forward a little...giving me a little forward lean..and putting the leavers where I like them...down a bit.
DJ
DJ
- PhillyScott
Thanks crousos, vinman and DJ Downunder for your replies!
I just returned from the BMW Finger Lakes Rally, where I enjoyed myself immensely! I had a chance to look at quite a few R1150R's, but all had stock handlebar set-ups.
I think one of my issues with the bars are that they seem fairly wide and was wondering if I cut an inch or two off each end, would I still have enough tank clearance?
Thanks again!
Thanks again!
Moto Guzzi 1000 S
BMW R1150R Rockster
BMW R1150R Rockster
There are some bars at BMW of Santa Cruz that they say are between the r1150r and the rockster.
http://www.bmwscruz.com/Merchant2/index.html
Go to R series and pick either Rockster or R1150r. They are called sportego handlebars, part#1624559.
- PhillyScott
Thanks, I'll definitely check them out!jrock wrote:There are some bars at BMW of Santa Cruz that they say are between the r1150r and the rockster.
Moto Guzzi 1000 S
BMW R1150R Rockster
BMW R1150R Rockster
Lenker
I'm with DJ:
Previously wanted lower/narrower bars in order to create a "sportier" posture for the Roadster, maybe something akin to R90 riding position. But now I'm content with the OE bars, primarily because of a lack of aftermarket options when searching 2 years ago, and more recently because I value the Roadster as do-most-everything machine better suited for wide/high bars (great for low speed handling).
The OE "Lenker" don't fit my hand/arm angles very well (need the pull-back angle reduced), so something like the Ricky Bars would probably work perfectly. Having blown the budget on other projects already, new bars for the R1150R will have to wait.
- PhillyScott
Re: Lenker
What are OE 'Lenker" and Ricky Bars?sweatmark wrote:I'm with DJ:
Moto Guzzi 1000 S
BMW R1150R Rockster
BMW R1150R Rockster
DJ Downunder
Here's Ricky's Bars... http://www.motomacondo.com
Click here for his nice moving pic http://patineto.smugmug.com/photos/3844053-O.gif
DJ
DJ
- PhillyScott
re: "Lenker"
German "Lenker" = steering wheel, handlebar (kinda sorta)
- PhillyScott
Re: re: "Lenker"
Oh, OK!sweatmark wrote:German "Lenker" = steering wheel, handlebar (kinda sorta)
Thanks, my German is not very good!
Moto Guzzi 1000 S
BMW R1150R Rockster
BMW R1150R Rockster
