ceramic coating my headers
billbeemer
Post by billbeemer »
on my '03 r1150r i need to remove my headers myself. my only concern is the header bolts attached at the head. any problems getting them off. they have never been touched. will i need heat? help, i don't want to screw something up
Re: ceramic coating my headers
Spray short shots of Liquid Wrench or Knock'er-Loose behind the finned casting onto all 4 of the bolt threads of a very warm engine and let it soak an hour+, respraying 15 minutes after the 1st spraying. Then they come off easy. I have easily removed a '98 R850R and '02 R1150R header bolts this way with no shear-fear or frozen-drama. Doing it dry could be a risk because of the years of heat cycle accelerated deterioration between the steel bolt/Aluminum threads junction.
mambopalace
Post by mambopalace »
Just had a place called NitroPlate in Tennessee do mine. They did an excellent job and the total was $107.00
I've also had them done by Jet-Hot. The NitroPlate was as good or better than the Jet-Hot. Included doing the inside of the header pipes.
SteveJJ
Donating Member #: 1113
Post by SteveJJ »
mambopalace wrote:Just had a place called NitroPlate in Tennessee do mine. They did an excellent job and the total was $107.00
I'd like to see a picture of the results. Are there color options or just black?
2003 R1150R
2007 DL650 "weeStrom"
