R1200R Asymmetry
Posted: Tue Oct 01, 2013 4:15 pm
by websterize
Is it true the clutch side and the throttle side of the fuel tank are shaped differently? I'm struggling to see it.
If so, why are they asymmetrical?
Re: R1200R Asymmetry
Posted: Tue Oct 01, 2013 8:04 pm
by AlecMyrddyn
It is.
It's pretty apparent looking down from above. My guess is so that the tank contours visually match the cylinders, which are not symmetrical from the top either. One is further forward than the other.
Posted: Tue Oct 01, 2013 8:29 pm
by dbrick
Look for the difference this way: the front of the seat has two "ears" that stretch forward; the seat ears are symmetical, left and right. Each "ear" fits into a recess in the tank. Look at the distance between the forwardmost point of the recess and the bottom of the tank: it's much greater on the left side.
Posted: Tue Oct 01, 2013 8:35 pm
Looks like thw wintertime posts are starting early
Posted: Tue Oct 01, 2013 11:51 pm
by Don C
The tank cut is higher on the right side at the bottom, it leaves more room there for the intake snorkle.
Posted: Wed Oct 02, 2013 8:44 am
by angellr
mogu83 wrote:Looks like thw wintertime posts are starting early
Weather here is still nice ... my advice would be to get out and ride another month or so and save these up ... could be a LONG winter!
Posted: Wed Oct 02, 2013 4:33 pm
by Mollygrubber
Posted: Wed Oct 02, 2013 7:09 pm
by MTBeemer
Wow, do we need ro run an asymmetrical oil as well to compensate?
Posted: Wed Oct 02, 2013 7:25 pm
by Clem
That's interesting Bill. I agree with dbrick and DonC. Air intake. Thank you gentlemen.
Posted: Thu Oct 03, 2013 3:08 am
MTBeemer wrote:Wow, do we need ro run an asymmetrical oil as well to compensate?
not necessarily - you can get away with balanced oil - BUT you MUST fill up witht he pump on alternating sides of the bike in a specific pattern to maintain the petro-chemical dis-proportionality within the tank.
On the 259 oilhead series the pattern was left, left, right, left, right, right, left, right. (then repeat). Pretty simple pattern because the oil heads were relatively well distributed above the line of the crankcases.
But I think the 1200 series pattern is: right, left, left, right, left, left, right, left, right, right, left, right right, left, right, left, left, right, left, left, right, left. (the repeat). That's the advice I got from my dealer when I hired one for a week.
Posted: Thu Oct 03, 2013 5:47 am
by websterize
Going on 4.5 years since I took delivery of this fine machine, and seems as if I learn something new every week. Thanks for the insight — and humor!
Posted: Thu Oct 03, 2013 4:15 pm
by websterize
On another R12R forum, someone named "sup909" pointed out that the valve covers on all boxers are offset -- just look from the top view. I love the interwebz.
Posted: Thu Oct 03, 2013 7:09 pm
by MTBeemer
I think BMW started making them that way because of their intent in getting into NASCAR with all the left hand turns..... pretty sure.
Posted: Fri Oct 04, 2013 10:48 am
Bill - the cylinders are offset - pretty much have to be since the BMW engine doesn't use a "simeased" (SP?) - ie - forked - connecting rod setup like Harley does. The connecting rod bearings for the two BMW cylinders run side by side - causing the offset.
Posted: Fri Oct 04, 2013 12:33 pm
by xprof
Is there an aftermarket single-journal crankshaft that I could install? That would line up my cylinders and also give me the engine shake and potato-potato sound I have been looking for.
Posted: Fri Oct 04, 2013 1:36 pm
by Snapping Twig
xprof wrote:Is there an aftermarket single-journal crankshaft that I could install? That would line up my cylinders and also give me the engine shake and potato-potato sound I have been looking for.
Absolutely!
However you gotta buy the Harley that wraps around it to get it.
Posted: Sat Oct 05, 2013 10:26 am
by xprof
Thanks, Snapping, but I've got a better idea: I'll carve one myself out of a block of cast iron with cold chisels...
Posted: Mon Oct 14, 2013 4:38 pm
by Steve H.
Just go back with pictures in a time even footpegs are assimetrical.It was normal for BMW boxers all the time.Sitting on thise bikes like you are preparing right leg to cick someone a.... !
Posted: Mon Oct 14, 2013 5:24 pm
by celticus
Standing behind my bike this weekend and thinking about this very interesting subject I took a look forward and sure enough you can see it from there. Easy as pie.
