Tire Size
Bruno
Tire Size
Post by Bruno »
2005 R1150R has a rear tire 170/60 zr17 can i go to a 180/55 zr17
omg1010
Re: Tire Size
Post by omg1010 »
You can - at your own risk. 170 = 5.0" rim, 180 = 5.5" rim ... I wouldn't recommend mounting the 180 tire on the 5..0" rim as it is not specified for the same.
I believe the R1150 shares the same rear rim with the R1100S and that bike had a 5.5" rim as an option. Checkout on egay.
Brgds
Oliver
tiPirate
Re: Tire Size
Post by tiPirate »
The 1100 uses a 5" rim also, correct? Can I go 170 on my 1100?
omg1010
Re: Tire Size
Post by omg1010 »
Which R1100 do you refer to? The R1100S was available with the 5" rim (170/60 x 17 tire) and with the 5.5" (180/55 x 17 tire) ... Hence with the appropriate rim you could mount the 170 or the 180 tire ... These rims can also be mounted on the R1150R.
Brgds
Oliver
harrisphil
Re: Tire Size
Post by harrisphil »
you can fit the wider tyre
but why?
IMHO the 170 handles better
Bruno
Re: Tire Size
Post by Bruno »
Thanks for the input guys The only reason I consider going wider is for aesthetics , thought it might look a little nicer
tiPirate
Re: Tire Size
Post by tiPirate »
Sorry, 1100R. 5" rim. 170 doable?
kirby
Donating Member #: 3
Re: Tire Size
Post by kirby »
mike Mojave CA
'04 ROCKSTER
tiPirate
Re: Tire Size
Post by tiPirate »
Only issue I can see is the clearance between the tire and the swingarm. Feels like there's about a finger's depth there now with a stock 150. :|
Anyone made the swap on an 1100R? I know I could swap to a 5.5" rear wheel (eg: K1200RS) with no problem, but is the offset between the two wheels identical? If so, a 170 should be no problem on the stock 1100R 18" three-spoke. Dissenting views? :-k
opposedtwin
Re: Tire Size
Post by opposedtwin »
Have a 2002 R1150R and I installed 180 Metzler Z6 on it with no problem. However, the 170 will have a more nimble feel whereas the 180 feel is a little more sluggish. My main goal was aestetics and hopeful by being a bigger tire it would last longer. Results:Didn't last longer. Everything else was a push.
omg1010
Re: Tire Size
Post by omg1010 »
On my old R1100R I had done a wheel swap to the 5-spoke design (front = wheel of R1150R, rear wheel of the K1200RS aka flying brick). At first I took the 5" rear rim with 170 tire and later on used the 5.5" rim with the 180 tire. Tires used were Michelin Pilot Road I and later the II. No problem at all and enough space between tire and final drive. I had even removed the steering damper. Handling was always very good and the looks obviously improved :mrgreen:
Brgds
Oliver
