Bar Risers
Bar Risers
2004 Rockster here in (very) sunny Bakersfield CA. I've had installed handlebar risers, appears the cables, in particular the throttle cable, are too short. Any suggestions on replacement cables out there? Many thanks for your replies. Sahsta
Re: Bar Risers
The cables were long enough for the "R" (roadster) bars.
Sorry I can't help, good luck
mike
mike
mike Mojave CA
'04 ROCKSTER
'04 ROCKSTER
Re: Bar Risers
Hi, I imported an ABS Rockster into New Zealand (from Alabama) that had bar risers on. There seemed to be no problems with cable or wiring length. I think the risers were about 35mm (approx an inch and a half). Maybe check that someone before you hasn't re-routed the cables incorrectly?
Re: Bar Risers
For reference, I've got 25mm riser blocks on my Rockster, with no problems associated with any of the cables or wiring. But please note that I have snipped ALL of the original wire ties, and removed the attachment clips that might bind the throttle cable housing movement.shasta wrote:2004 Rockster here in (very) sunny Bakersfield CA. I've had installed handlebar risers, appears the cables, in particular the throttle cable, are too short. Any suggestions on replacement cables out there? Many thanks for your replies. Sahsta
The best way to assess cable slack/binding is to remove the fuel tank, allowing clear view of the various runs from handlebar to associated connections.
Re: Bar Risers
Kirby - you're in Tehachapi? We're doing the Lions Trail, back way to the poppy preserve, Kern Canyon et al on any given Saturday. Breakfast in Keene or Tehachapi depending on the day's ride. This Last Saturday it was to the top of Mt Pinos and home via Maricopa. What say you we coordinate a ride? Riding weather is fast upon us.
Shards - I'm looking into re-routing the cable group from the front to back of the forks as per another posters' previous advise. Thanks for responding.
Sweat - I confirmed that the ties have been snipped, will see about the tank removal for a visual inspection. I appreciate your response.
- grwrockster
Re: Bar Risers
I have R1150GS 'bars on my Rockster, and if routed properly the throttle cable isn't a problem.
With the rise of the GS 'bars the throttle and brake lines are very marginal though. I got away with the brake (just) with a bit of mucking about, and to get the clutch line working I pulled the tank back and re-routed the clutch line ABOVE the front tank mount (prior to this it ran UNDER the front tank mount).
I did run risers with the stock 'bars before this (about 1.5" higher and 1.25" further back) and all lines and cables presented no issues.
So - a bit of careful routing should see you sorted
Re: Bar Risers
I have risers too, (not sure what the offset is), but the cables are fine, just make sure they're routed efficiently and not cable-tied to anything they don't need to be.
Re: Bar Risers
grw, rice. I've passed your suggestions on to my "ace" mechanic. Many thanks for your advise. BTW, the risers are the Verholen for rockster. I've also ordered the r1150r throttle cable said to be 2" longer than that on the rockster. I'm ready to ride, man. shasta
