To my amazement I discovered that I would rather ride home in 105 degrees than drive home in my truck... and I love my truck.
The temps in North Texas have been in triple digits for over a week at least, but the mornings are fantastic. On Tuesday the outside temp registered 79 degrees for about a minute as I passed through a long low spot between hills… big smile behind the visor.
I’m coming up fast on my 6K service interval (about 5400). I’ve used about 1.5 quarts of oil between the 600 mile service and now. Seems a bit late to get worried about the heat, but do you think I should give the bike a break during these brutally hot afternoons?... maybe just try and get it serviced now, instead of waiting until the 6K mark?
Last comments about the heat – If you want to remove the R1200R graphics from the tank, just set it out in the noon sun for 30 min (but you need to be in Tejas)...it turned the sticker removal into a 5 min job. I also removed some of the other stickers on the forks and frame which also came off quickly (but in pieces) … I don’t like stickers.
Cheers and thanks in advance for your feedback…
