Quick Disconnects will be here Monday. Whats required when making the change? Empty the tank? or remove the tank
Cut or bend the original hose clamps to remove, with dykes(side cutters) any additional fuel line needed?
Thanks.. [email protected]
Quick Disconnect Change Info Needed
RadicalR1150R
Re: Quick Disconnect Change Info Needed
May want to change the Air Cleaner and new Battery while the tanks off, that's my plan. Also going to hook up my Jacket lead to the Battery.
02R1150R,02R1150Rabs,04R1150R
02R1100S,05R1100S(BCR),
(2)-S1000XR
IBA#7147
IBA#7147
- frkn_toaster
I just replaced mine today!
The old ones were a bitch to remove – I took out the bike-side QDs first, which came out after a lot of wiggling. Then I used those pieces to plug into the tank-side QDs to get better leverage (and I imagine there is some suction-related advantage in that too).
I left the existing fuel lines, they're in good shape.
I cut through the existing clamps *very carefully* with a dremel (I know this is dumb and there is a better tool for this)
I did not drain the tank, just kept a few golf tees handy to plug lines.
Those chrome/brass replacements are really slick and they're going to make it so much less of a hassle to remove the tank.
- Dr. Strangelove
- Double Lifer
That is actually a common way people do it. Scary, yes, but I haven't heard of anyone blowing themselves up with that technique.I cut through the existing clamps *very carefully* with a dremel (I know this is dumb and there is a better tool for this)
'09 Schwarze Blanche DuBois
Changed them on the 02 today and all is good. Only thing is the FI hose clamps leave a long bolt end sticking out from the clamp, have to angle them appropriately so they don't chaff anything.
(2)-S1000XR
IBA#7147
IBA#7147
- Dr. Strangelove
- Double Lifer
you can get vacuum end caps to cover protruding screws. Home depot lowes, etc. you've seen them, you just didn't know what they were called. Might find them at Pep Boys or Advance Auto also.
Like a little piece of plastic or rubber that slips over the end of the screw.
I pick some up, thanx.
(2)-S1000XR
IBA#7147
IBA#7147
