Help with windshield install on a '12 R12R
Posted: Tue Oct 18, 2011 9:25 am
Just got a sport windscreen kit for my 2012 R1200R, which came with no installation instructions (naturally). It appears pretty self explanitory, with one exception. There is a piece of plastic trim that covers the panel between the headlight and the cluster. The bracket for the screen mounts to a section underneath this trim. I can't figure out how to tighten the front two bolts, and still be able to replace this trim. Does the instrument cluster need to come off?
Anyone who has done this, if you could throw me a couple of suggestions, I'd greatly appreciate it.
It's basically 4 bolts, and I'd hate to pay the dealer to do this...
This shows the two holes the mount bolts to (with the appropriate clips) right between the two "connectors" - The trim basically covers all the wiring.
Here is a diagram showing the problem area. I can’t figure out how to get at the two front bolts, which screw into clips installed just north of #10, and still have the plastic trim piece, #9 that covers the trim panel in place. You can’t get the trim panel on once the bracket is installed, and you can’t install the bracket with the panel on... A conundrum…
