Camping, CPAP and other stuff ...
Posted: Wed Jun 15, 2011 7:43 am
There are a few on this board who have Sleep Apnea (including yours truly) and have done extensive research and wanted to share some of my results here.
First off, I have had this condition for over 20 years. Have schlepped and used machines all over the world (even in some pretty remote places of the world - eg. Cochin, India) and have always had power of some kind. Wanting to break free from the bonds of being chained to a power source has led me on this quest. Believe that I have found something that will work for at least ONE night as follows:
1. You will need to do some research on the power draw that your machine has on an hourly basis. Mine roughly draws 1 Amp/hour WITHOUT humidifier. You must get a DEEP CYCLE marine LEAD ACID battery (way too heavy in my IMNSHO) or go with a Lithium Ion (stability OK) or Lithium *Iron* of which you will need roughly DOUBLE the Amps for your projected usage. I decided on step 2 below.
2. Obtain the 2.5lb battery pack from CPAP.com which will allow you to use your machine for at least 6 hours. You will need an inverter if your machine does not accept DC power directly. Some machines you will fry if you are not careful. This is roughly $300. Make sure you get the DC adaptor with the unit.
3. If I run out of juice camping, I will use my H20 proof duffle to prop upper body underneath my pad/sleeping bag. This should do trick for at least one night here/there.
With step 2, I will roughly get 8 hours on a single charge, therefore, can camp every other night or make sure the camping facilities have a power source or go with Step 3.
Am still researching whether or not I would/will be able to re-charge the battery pack in #2 while riding all day. Any thoughts from the collective group whether this might be doable?
Hope some of this helps.
Thanks.
Thanks.
