Ever see a bike trailer like this?
Posted: Wed Mar 23, 2011 8:06 am
Sticking my neck out here, so be kind -
and be gentle if you can't be kind
For some time I've wanted a bike trailer that's easier to load / unload
than the converted boat trailer I've been using - it's just too high.
(I had it, so been using it)
After much thought and many ideas, this is where I stand currently.
I make all my own stuff - I just hate to pay somebody umpteen hundred $
for something I can build myself. Besides, figuring it out and building it is
half the fun - at least when it works. And then sometimes I even get it
like I want it
(or
So - want it as small and light weight as possible to tow behind a small
sport wagon. Want to be able to store it in a small space, so have designed
it so it's easy to stand up on end and it will stand by itself.
Also want it low so it's easy just to roll the bike up onto it. Needs to tilt
so I don't need a big long ramp that I have to haul with and secure to the
trailer during the trip.
I have a boat trailer axle (replaced it with a heavier axle for my converted
multi-purpose trailer) that has the typical 12" wheels and has a fairly low
centerline - about 10" high. If I can make the "bed" of the trailer the same
length as the bike, it won't be very long and then a 10" frame clearance
should be enough if I'm reasonably careful and don't go off-roading with it.
I don't use a trailer very often, but when I do it's often a longer trip when I'm
likely to be carrying a load of other "stuff" so want it to tow easily, which the
lighter weight also helps. Light weight also translates into less material to buy,
and a simplified design makes it easier / quicker to build. I've roughly figured
the trailer at or not much over 250 lbs, if that.
Rather than try and explain it, I've drawn up an admittedly crude drawing in
Excel. I didn't draw in all the components but rather put notes in about some
of those details that should make it pretty obvious what I'm intending.
http://www.mediafire.com/?n2jev4xz81euj
Remember - be kind. And if you can't be kind, at least be gentle.
like I want it
