Since your problem seems to have started after you put gas in it,
it may be that stirred up water that before had been laying on the
bottom and now has been mixed in with the rest of the gas in the
tank (most likely), or something else laying on the bottom, as has
been suggested.
I would strongly suspect that before starting to replace any parts.
Personally, I'd remove the gas tank and dump it out and then put some
fresh gas in there and slosh it around and dump that out, do that a
couple times. Watch what comes out to see if you see any particles
or anything that doesn't belong in there just in case.
As also previously mentioned, it would be best if you got a set of
the metal quick disconnects before you even start - they are
pretty fragile. Even if you succeed in disconnecting and reconnecting
them, they can suddenly fail at any time anyway.
You can get them at
http://www.beemerboneyard.com
And you need the big O ring that seals that assembly to the tank.
One would think the existing O ring could be reused, but everything
I've read indicates it has to be replaced in order to get a good seal.
And the little bolts that mount that assembly to the tank have to be
very carefully tightened so as to not overtighten them as I've also
read they can fail if over tightened.
I bought an 04 in summer of 08, my first BMW with no previous BMW
experience at all, and have gone thru the learning curve on the
peculiarities of these particular bikes. After you solve this particular
problem it should run pretty well for awhile being virtually new, although
the factory tune-up tolerances can be improved upon. Particularly the rocker
arm end play, the valve lash, and the throttle body synchronization.
The last job I tackled on mine, and that was just this summer, was the
fuel filter. As designed, the tank has to be removed and the pump / strainer /
filter assembly removed from the tank. I had read a number of posts about
how much of a job that can be, and about an option to remove and bypass
the in-tank filter and mount an external filter instead. Of course, that's a
non-recommended procedure from BMW and doing that you take on the
responsibility should anything bad happen as a result.
As I really didn't want to go thru that hassle with the in-tank filter again,
I took the plunge, and am glad I did.
For reference, here are some part #'s:
The big O ring for the sender assembly 1 16 14 1 341 008
the strainer 16 14 1 341 233
the filter 16 14 1 325 859
There are some hose clamps you'll also need to replace. The stock ones are the
crimp together type which are not only difficult to remove but you have to have
a special tool to install new ones. You might want to consider getting efi hose
clamps from an auto parts store which are the type with the screw to tighten.
I used those when I installed my external filter and have had no problem. The
fuel pressure in the bike is no higher than that on a typical efi car and those type
clamps are used on cars routinely.
Just in case you're interested, here's a link to a BMW parts fiche for the r1150r
http://www.ascycles.com/Illustrated_cat ... meset.html
And here's a link to my external filter installation
http://www.mediafire.com/?dj2jjdyjlm0
Like I said, all the usual disclaimers apply - only attempt this if you're
fairly well experienced working on vehicles
There's a lot of good information available in this forum and on the internet in general.
IF you're like me, and many other forum members and riders, you'll be interested in
learning about these bikes and what it takes to maintain them. Just ask.
Good luck!
PS - even with the low miles, you might want to change the engine oil, the transmission
oil, and the final drive oil. That much is pretty simple. Also to totally bleed the brake system
and replace the fluid, and the hydraulic clutch too.
If you have the ABS brakes version, you'll probly want a dealer to do the brakes at least the first time.
But be prepared - ask how much they'll charge before you OK the work. The ABS system is
pretty complicated and can cause problems if not done right. All the info is available but be
sure to read and understand and be comfortable with it before you tackle that one.
