Tire plugging
Posted: Sat Apr 25, 2009 10:06 pm
Ever wonder how well those plug kits that come with the bike work?
Ever take comfort in knowing that it's there, just in case, even though you're clueless about how well they work.
Ever wonder if you've got the nads to make that thing work alongside the road in, say, rural Appalachia, with the banjo's dueling in the distance..., at night..., hearing the occasional pig squeal..............?
Well, did ya?
I was always pretty smug thinking this little jewel of a kit was right under my behind for those rare emergencies.
Time for a new rear. Time to learn how well that little kit works. Learned the value of training in the Navy, if for no other reason than to know firsthand that your OBA works and you really can put out that 20ft high fire working w/ 5 guys you never met before.
I drove the screw in, jammed it around some & screwed it out; didn't leak much until I reamed the hole per the instructions. Next time, I'll be sure to have the plug ready the second the reamer comes out, to minimize air loss. By the time I got the plug gooped up the tire was so flat I could push it in halfway to the rim.
How's this thing supposed to get in there if it breaks when I try to shove it in?
WTHDIDN (What The Hell Do I Do Now?)
Found this in the bottom of my toolbox, been in there since I drove home from NAS JAX in '90.
Goes in, stays in, holds air?
Used up all three cartridges, only got up to 20psi. Time to improvise; didn't kill the battery or overheat the bike using this, but only got it up to 30 PSI because the thing works so slow. Figured 30 was enough to get to the gas station air.
I'll be looking for the world famous Cycle Pump or equivalent over the next week or so, this things just too big.
Realized I better stash some quarters in my took kit if I plan on using one at the gas station in the future.
Took it for a ride to the gas station, realized I left my air gage at home. Better make sure I keep one in my jacket AND in the tool kit, because I'm stupid enough to lose one of them. Then I realized there was a gage on the air hose at the gas station. Took it up to 40psi. Ran some errands, took a few back roads, came home w/o incident, seems to be holding air;
Learned several things;
1. I'm not sophisticated enough to use the Teutonic version (or maybe the plugs were as old as the bike; '02) or maybe those plugs are just a little too fancy of a design.
2. The Wally World stuff sometimes holds up, even longer than the Teutonic version, sometimes for decades, sometimes simpler is better. Looking for guidance from somebody with more experience as to what is best and why.
3. Three CO2 cartridges work, sorta; I'm buying one of those electric inflators to stash on the bike somewhere
4. Keep some quarters in the tool kit, and leave them there for actual emergencies, not a jones for java
5. Latex gloves will have a permanent place in the tool kit with the Wally plug stuff and quarters and tire pressure gage
6. Riding on a plugged tire isn't my idea of fun, but I know I can do it if I really have to, at least if the hole is pluggable
7. A little preparation & training brings a lot of peace of mind (sorta)
Well, did ya?
