I have a line on a y-pipe off a 2004 r1150gs is it compatible with the 04 r1150r?
Thanks,
Dan...
1150 gs compatiable with r1150r?
Re: 1150 gs compatiable with r1150r?
Dan --
I have been running a Sebring Y-pipe from a GS in my 2003 R for years now. I'm pretty sure that the '03 and '04 Roadster's have identical exhaust systems but I don't know if the same is true for the GS. I found the Sebring in the IBMR.org site want ads.
BTW, one small issue with the Y-pipe is that the OD of the tubing is slightly smaller than that of the cat it replaces. This means that the clamp is a bit too large to cinch things down. My solution was to cut some shims from sheet aluminum to use under the clamps. Others have used hydraulic system clamps or have cut the stock clamp's spacer to allow it to contract a bit more.
Charlie
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
allanj255
Exhaust system on GS & R are Interchangeable. I have second hand Remus Y pipe and end can off a 1150GS on my 1150R
Allan
Awesome, thanks for the info!
