First impression of the V-Stream shield from ZTechnik is it's made well, with a very strong frame and attached as good as the BMW stock frame. The color matches the grey color that is found on the bike. It is best to have 2 people to install as you have to raise the handlebars and slide the frame under the bars and cables. I have Wunderlich bar risers and had to slide the risers to the aft position in order to fit the bracket. I did have them in the center position but I have no problem with this setup.
I went with the black bar ends to match what came on the bike and they have some texture as well. I thought they might be better with gloves than a smooth finish.
The handguards went on just as Ka5ysy said they would. My fab work isn't as good as his
I hope to get a ride in this Fri as the temps go to the upper 50s and see how this shield does.
More to come.
