Re-routing the wiring harness for handgaurd installation
Posted: Thu Jan 15, 2009 4:51 pm
by zeke
So last summer I put barbacks on my RR. Love them work great, better position and all that. During the installation I had to create slack in the wiring harness by cutting the tight zip ties.
Recently I got handguards. I then discovered that there is not enough slack in the wiring harness to easily install the handguards changes are in order.
My plan/thought is to remove the headlight and turn signals, then remove the handlebars. Reroute the wiring harness to the other side of the large piece of metal that supports the headlight, creating the slack I need, and then put everything back together. Then add the handguards.
Has anyone addressed this before? :-k Suggestions? Look forward to getting into this project and getting the handguards installed. Thanks for any help. :smt023
Re: Re-routing the wiring harness for handgaurd installation
Posted: Fri Jan 16, 2009 3:10 pm
by Beemeridian
11
Posted: Fri Jan 16, 2009 7:29 pm
by zeke
Beemeridian,
Thanks for reply. I did read your posting (in dec), so that was a good assumption on your part. Are those SW Moto barbacks? I bought a set from them as well, and love them. The post was helpful..... but maybe I am just paranoid about stressing the wiring harness. I remember reading many posts about the zip ties being too tight...etc.
I was thinking it might be better to re-route the wiring harness and cables from their current position to the space between the forks, and the headlight assembly support a bit closer to the fuel tank and handlebars. I am concerned that in attempting to alleviate my perceived issue that I would actually make the situation worse, and have to take the bike to the shop :smt022 that would suck.
Anyway I'll have to take a real close look to see if it would even be worth while to go through a lengthy or complex process with the headlight. Luckily winter is in full swing and I have plenty of time to sit around and pine over this issue. Thanks again. :biggrin:
Posted: Sat Jan 17, 2009 8:00 pm
by jonboy59
It is actually pretty easy to take the forks out of the top of the tree and slip the cables to the other side. I have 3" Rox risers and handguards and have ample slack in the cables. You may need to relieve some of the plastic on the guards.
Posted: Sat Jan 17, 2009 9:56 pm
by Beemeridian
11
Posted: Sun Jan 18, 2009 10:14 am
by zeke
Second the motion on pics, and further description!
