How to Repair Scratches on Panniers
bmwfbd628u
Post by bmwfbd628u »
Hi,
Just bought a 2003-made 2005-registered Rockster. It came with panniers but with some rather unsightly scratches. Would like to seek suggestions to repair them at minimum cost. One option is to paint them over. Another is to use stickers, if can find appropriate ones for the different scratches. Thinking whether can I sand away the scratches before spraying protective transparent paint?
Tks in advance for any suggestions.
Boxerpunk
Re: How to Repair Scratches on Panniers
Post by Boxerpunk »
What do you think of black relective sheets ?
http://www.cyclegadgets.com/Products/pr ... sp?Item=RK
Available in uncut sheets 8" x 10" (203 x 254 mm.)
Greetz, Erwin
2003 Rockster Full Black
bmwfbd628u
Found out that BMW Motorcycle sells rubber pads for panniers, to protect/cover the exact spots where scratches are usually found, ie front/side mid curved section. Will check it out, and post an update if anyone is interested on how they look.
WildBlue
Post by WildBlue »
I am interested in pictures when you are done.
Chris
2002 BMW R 1150R ABS, Black, 27,000+
Life is a Game. Play to win.
lionlady
Post by lionlady »
If the scratches aren't bad, you can use emory paper (black) to smooth the worst of them off.-Start with medium, then go with fine... to blend them in. Chances are no one will notice them (but you) once you've done that. Finish with a coat of "Black Magic/Back to Black" from Mother's (or was it MacGuires) - in a red bottle.
Its tough to get paint to stick/stay because the plastic cases flex.
P
ronnierockster
Post by ronnierockster »
May I suggest that you are wasting your time. If you use the boxes you WILL get marks on them however careful you are. That's the way it is.
They keep you stuff dry,stop it from falling onto the road. What more do you want . Go on a trip with them.
Have FUN .. 8)
See Ya...RR
lionlady
Post by lionlady »
bmwfbd628u wrote:Found out that BMW Motorcycle sells rubber pads for panniers, to protect/cover the exact spots where scratches are usually found, ie front/side mid curved section. Will check it out, and post an update if anyone is interested on how they look.
I've seen those rubber pads. They're FUGly. Thick (about 1/4 inch) - they stick on the cases and then if you scrape THEM . . .
Like ronnierockster says, you're probably wasting your time. If they offend you THAT horribly, then emory paper will make them less noticeable until you can find a decent used set (buy one at a time on eBay, etc) or new.
P
bmwfbd628u
lionlady,
You are spot-on about the rubber pads - look ok on schematic (on dealer's digital record) but out-of-place in real (on a bike being serviced at the dealer). Also, as with all BMW parts, they are costly - US$50 each. Will take your advice to sand the scratches much as I can, and live with them. Thanks for the advices.
