My son, Chris, was in Colorado on my '02 R1150R staying with family. While out there, he and his uncle replaced the worn rear tire. I went out a couple weeks ago to ride back to TN with Chris on my FJR. While there, we did some awesome rides around Gunnison. On one ride up the Taylor canyon, my bro-in-law was leading, then Chris, and me in the rear. Suddenly Chris pulled to the side of the road. When I pulled up behind him he said that the R1150R was handling funny. We put it on the center stand and after a few seconds of wiggling stuff we realized that the lugs holding the rear tire on were loose! Holy $@#*
I really don't know why this happened. Both Chris and my BOL are experienced tire-changers, and I find it hard to believe that they did not tighten the lugs properly. They didn't use a torque wrench, but they remembered tightening them down hard using the standard cross-pattern. Chris had ridden the bike at least 1000 miles since the tire was changed. He did have one mid-speed, low-side slide out on a wet dirt road, but I don't see how that could have affected the tire. Either they didn't torque it down properly, or the lugs found a way to work themselves loose under normal use. I hope it's the former.
Like I said, I'm sharing this as a warning to others. It wouldn't hurt to check the lugs periodically. I'm also curious if this has happened to others. Is there a tendency for the rear lugs to work themselves loose on these bikes?
