Autoswitch help
Jayken
Autoswitch help
Post by Jayken »
Hi Guys , I need help with wiring the Autoswitch/Easternbeaver relay/piaa 1100X, most of this is done but the damm autoswitch will not activate the relay. Anyone who has this set would like to help around the Lehigh Valley PA area.?
regards
Jay
johnnyjs1
Donating Member #: 607
Re: Autoswitch help
Post by johnnyjs1 »
How far is that from cleveland? There are a few threads about the autoswitch, I had some trouble as well, but got it figured out
09 Someting??
Lifer 607
Jayken
Re: Autoswitch help
Post by Jayken »
Thanks for the offer johnnyjs1, I am about 6 hr away. If you are in the area of Eastern PA, you can stop by. Well I think I have it all hooked up correct, but for some reason the lights won't come on. I have the orange wire tapped into the brown/white under the fuse box, black to ground, the Violet to the relay, and the red to #2 fuse, but no go. The led stay's lit red.
I just can't figure it out.
regards
Jay
johnnyjs1
Re: Autoswitch help
Post by johnnyjs1 »
Do you have the violet and wires from the lights going to the correct poles on the relay? I think that was my problem, until i started switching the wires around and testing until it finally worked. :-k
09 Someting??
Lifer 607
