Weak headlight=weak battery
gel9001
Post by gel9001 »
Hope this question doesn't sound to dumb My 2004 is up for a replacement of its gel battery, but I was hoping to put it off till end of summer, but recently especially this morning I've noticed the headlight is quite dim. Would this be a simple indication that battery is weak.
I hooked up a volmeter to it a few weeks ago and it read over 12 volts, but with starter cranking, voltage dropped to 9.5 volts.
thanks for any suggestions, with this dim headlight I'm very concerned that the battery can go at any time.
thanks,
Gene
Buckster
Donating Member #: 543
Re: Weak headlight=weak battery
Post by Buckster »
I would charge the battery and then check it again. It's probably on it's way out though with the voltage that low.
My bike is an '03 with the original battery and it's still going good.
Buckster '03R
#543
gel9001
Post by gel9001 »
Well I don't think I have to charge my battery, since I ride everyday and alternator handles that.
My dilema is do I buy a battery tonight or will it hold till Saturday.
Arbee
Post by Arbee »
Batteries are completely impersonal things and will breakdown when and where they want
no matter how much wishing or cussing from the owner will change their path of unsympathetic decline..
Personally i think that you are measuring the wrong things, measure the battery voltage whilst the engine
is running not cranking.
Boxer
Donating Member #: 2
Post by Boxer »
Only true, of course, if your alternator is functioning properly or the belt is tight enough and not slipping.
The battery going down like that under load is a sign of something amiss. Al will know about this battery stuff....
Paging Boxermania!
Airman
Post by Airman »
Paging Boxermania!
Don't wait too long.
Seems like I remember CycleRob saying one time that the battery voltage should not drop below 10 volts or so while cranking. I may be incorrect but at any rate your battery is 4 years old. My 04's went this past December. No real advance warning. You would not be hurting yourself at all to go ahead and replace it. Would probably save some embarrassment and agravation later.
KHaynes
Post by KHaynes »
If your battery is over three years old it owes you nothing so don't feel too bad about replacing it.
If the "state of battery charge" is poor you will often see your headlight brightness increase as you rev the engine.
Beware... batteries can die very quicky.
Keith Haynes
R1150RT
Wheelcaps
Eqyn Dad
Post by Eqyn Dad »
I replaced my 3.5 year OEM battery this weekend with an Odyssey; really wasn't any big deal - just had to bend the positive terminal flat for a better fit and add an extension to the negative side.
Upon starting I noticed 2 things immediately: the starter turned much faster and the headlight was definitely brighter with NO fading upon revving.
...replace that OEM battery, it will be worth it. I found the Odyssey shipped free for $131.
