Sold my Kawasaki Vulcan 900 Custom. Here's the replacement.
Posted: Sat May 17, 2008 5:01 pm
by garylspolar
It has 1 HP (Human Power). I am tweaking that power daily at the gym, however.
Review:
Probably the most anticipated member of Bacchetta’s debut line-up is the dual 26" Strada. Big wheel ‘bents are quickly becoming all the rage in the American recumbent market (The 2002 Saber and Reynolds T-Bone are also gaining a lot of attention) and the Strada has looked to be a worthy addition to this burgeoning niche market since its Interbike 2001 debut.
Highracers, as many call them, were not born in America. Manufacturers such as M5 and Challenge have been successfully building large wheel recumbents in Europe for many years. The theory behind using two large wheels rather than the large rear/small front combination more common on modern SWB’s is that the decreased rolling resistance of the larger wheels should increase performance and confort. Since the addition of the large front wheel often raises the bottom bracket height significantly anyway, most of these highracers finish off the aero treatment with fairly laid back seat positions similar to that of a lowracer (hence the catchy highracer name).
Bacchetta co-founder, Mark Colliton, has been on the American big wheel bandwagon nearly since it started rolling. Colliton’s personal love affair with highracers began in 1992 when he first began talking to Warren Burger about big wheel bents. He later began experimenting with big wheels on his RANS V-Rex (a bike be co-designed). The performance increase was definitely there and Colliton’s mod gained a modicum of popularity in the late 1990’s. Mark also added a dual 650C Aerocycle to his stable a couple of years ago. Its high performance validated what he had already seen in the dual 26 V-Rex.
Therefore it was no surprise to those of us that know Mark when it was announced that the Strada and its two big wheels would be included in Bacchetta’s premier line-up. Internet buzz and longing stares immediately followed the Strada’s launch.
Like the Giro, the Strada is built on a teardrop-shaped monotube frame. It also shares its seat and stem/handlebar with the 20/26 Giro.
The Strada’s frame does differ slightly from the Giro in that it is designed to accept either a standard mountain bike size 559mm 26-inch rear wheel or the 650C size that is common of Triathlon bikes. In place of the Giro’s Bacchetta-made 20" aluminum fork and front wheel is a polished aluminum Kinesis fork and wheel that can also accept either 26-inch size. This will allow owners to utilize the many multi-use wheelsets and tires available in the 559mm size or give them the option to switch over to some of the ultra high performance aero wheels and very fast tires available for 650’s.
The Strada’s component package also differs from the Giro and definitely has a road bike flair. The Shimano 105 derailleursand the 12-27 Ultegra cassette are all roadie standard issue. The slick-looking FSA Gossamer crankset and its ramped and pinned 53-42-32 rings are less common but still road oriented. A pair of SRAM Rocket Shorties guides both derailleurs through the gears. I’ve said it before and I’ll say it again… The combo of a pair of SRAM Rockets and Shimano derailleurs is as close to shifting perfection as you’ll get.
The big-wheeled Bacchetta rolls on a pair of Alex rims laced to a set of Shimano 105 hubs. These wheels are shod with Specialized Turbo 26x1 inch tires. I had never laid eyes on these rims or tires (at least not in 559mm 26-inch size) before receiving the Strada. The wheels stayed true and I really liked the shiny black look of the slightly aero profile rims, but I was most impressed with the Specialized tires. These tires are very popular with my roadie friends. Now I see why. Roll down tests proved them to be a tick slower than the Schwalbe Stelvios I use on most of my bikes, but the ride was a lot less harsh and they stuck like glue in the corners. The Specialized Flak Jacket Kevlar belting also prevented any debris-related punctures during my test. This is definitely a tire that I would stock if I were a recumbent dealer who could get them.
The Strada’s Kinesis fork is also a fairly common item on high-end road bikes. What isn’t common is the dual pivot front brake attached to it. At first glance it appears to be a common dual pivot road brake. Closer inspection reveals that it is far from common. First of all, you’ll see that the cable pulls from the left side of the brake rather than the right. Cable/chain interference has long been one of the hang-ups of SWB recumbent design and has previously made the use of a decent dual pivot brake impossible. The Strada’s front brake also has a larger range of adjustment than most to accommodate the bike’s 650C compatibility. If you didn’t realize that a brake like this was available, don’t feel ignorant. It wasn’t. Bacchetta designed and contracted this custom piece just for the Strada. Custom components like this are not cheap but the powers-that-be at Bacchetta did not want to compromise the Strada’s braking performance just to save a few bucks.
A pair of Shimano levers actuates both the custom front brake and the Avid Single Digit at the rear. These levers are designed by Shimano for their flat-bar road grouppo and are intended to work with dual pivot road brakes. They weren’t designed for a linear pull brake like the Strada’s Avid. Bacchetta compensates for this with a Travel Enhancer adapter. The front brake provides very good feel and power, but the Travel Enhancer doesn’t quite make up for the lever incompatibility on the rear. Power was acceptable but the modulation and feel were not very good. The rear brake was also a little difficult to properly adjust. Bacchetta is looking to obtain a pair of matching custom levers (regular pull left, linear pull right) to alleviate this problem. Again, custom components are expensive and we’re not sure if or when this will actually appear on the Strada.
This impressive package weighs in at a very respectable 28 pounds, just as Bacchetta claims.
Of course, fancy parts don’t mean squat if the bike has the disposition of a squirrel full of Starbucks and is as comfortable as a bed of nails. Fortunately, the Bacchetta’s high roller is far from either.
Highracers don’t have the best reputation when it comes to user-friendliness. Many that came before the Strada were definitely not for the short of stature or weak or heart. Poor low-speed handling was an especially common malady. From the outset, Mark Colliton and John Schlitter aimed to buck this trend. The term "useable performance" seems to have been their mantra.
Getting started on the Strada really isn’t that much harder than it is on a P-38 or any other similar high bottom bracket short wheelbase. This was quite a pleasant surprise. Extremely low speed turns do reveal a fair about of heel interference and a tiny amount of wheel flop, but most riders will quickly adjust to this.
At any speed above 10 mph or so, the Strada is a dream machine in the handling department. On center feel is great. Above 17 mph or so, I was easily able to ride the Strada hands off. Turn-in is very predictable and the Strada’s compliant frame doesn’t get out of shape if there’s a small bump in the apex of your favorite curve.
The only real flaw I found in the Strada’s handling was one that I’ve found in most every dual 26" bike I’ve ridden. The front end of the bike just didn’t feel quite as stiff as a more conventional SWB. The flex wasn’t in the frame but seemed to be centered more in the bike’s fork or perhaps in the front wheel. It never showed at all during normal riding conditions but if you ever had to wiggle the bars back and forth quickly, you could feel a little bit of uncertainness. In all fairness to Bacchetta, I specifically checked for this after riding a few very wanky big wheelsers and probably wouldn’t have ever noticed it otherwise. Regardless, it was still the most solid dual 26" bike’s I’ve ridden and it may just be the way dual 26-inchers feel.
Most Bacchetta owners will most likely be going way too fast to be shaking the handlebars around anyway. The Strada can MOVE!!! The frame is plenty stiff where it needs to be and the Strada’s excellent aerodynamics and low rolling resistance all combine to make a damn hot little number. On short rides, the Strada wasn’t quite in the same league as my Challenge Jester benchmark, but it was quite a bit above the rest. I found it to be about 1-1.5 mph faster in average and top speed than I am on the more conventional SWB’s I have had at my disposal recently (Lightning Phantom and Barcroft Dakota). The Jester was another 1.5-2.0 mph faster than the Strada. On the track, I think that this margin would probably favor the Jester a bit more.
The main difference was that those one-hour blasts on the Strada were done in complete comfort. The Bacchetta seat and handlebar layout made it almost effortless to rack up the miles on this bike. For my build, the Bacchetta Re-Curve seat is about as good as it gets. For the Strada’s riding position, I even prefer it over the RANS seat. I also found that the Bacchetta’s handlebars were perfect for me ergonomically.
Mark’s big wheel design also helped to improve the Strada’s comfort. The dual 26" wheels weren’t only fast, they also rolled over most tiny road imperfections without transmitting any road shock back to the rider. The total package was so comfortable and so well behaved that I was often surprised to look down and see speeds of 21-23 mph on the computer when I felt like I was only going 15-16.
This comfort level allowed me to make up a good chunk of the speed I lost to the Jester on longer rides and especially on longer rides on rougher roads where the dual big wheels really shine. On the two metric centuries I road on the bike, my times were much closer to those of the Jester, only half a mile to a mile an hour off. I expect this will be even closer after a century.
Due to its lighter weight, the Strada climbs much better than most lowracers as well. As a matter of fact, its fairly low weight and high bottom bracket allow it out climb a whole lot of recumbents. The Strada is right up there with the P-38 in mountain goat abilities.
In short, the Jester is still the faster bike, even over the long haul, but the Strada is certainly close enough to make me choose it over the Jester for longer rides. If the ride is hilly, the Jester may not be faster at all. Why do I keep making this comparison to the Jester? Mostly because I keep getting asked. Comparing the Strada to a lowracer is really like comparing apples to oranges. A bike like the Jester is intended for the track. In many ways, calling the Strada a highracer doesn't even seem fair. This bike is definitely a ROAD machine with all of the necessary concessions to comfort and practicality.
On a side note - I noticed one interesting phenomenon while riding the Strada. One of the aforementioned metrics was an organized ride with about 200 roadies and two recumbents (myself on the Strada and Mark Cooper on his Ti-Rush). Quite to my surprise, the roadies actually liked this bike! It may have been that it had two big wheels like their bikes did or the fact that they can actually draft of it due to its higher seat height, but they were definitely impressed. They seemed plenty comfortable with me cruising in the main pack. Instead of asking, "Can that thing climb?" or "What made you switch to those?" the most common question was "How much does that thing cost?" I probably handed out about 10 or 12 business cards.
So is the Strada the dream bike that many have said it would be? It’s pretty darn good, that’s for sure. However, I have to admit that this is "my kind of bike" and may not be for everyone. I have relatively long legs and don’t have any problems with laid back seats or with the Bacchetta handlebar position.
While I really think that the unique handlebars will become a non-issue for most riders that give it a fair shot, some riders will certainly not acclimate as easily to the Strada’s extreme riding position. The severity of the seat angle is somewhat offset by the seats excellent design, but a high bottom bracket is still a high bottom bracket and some people may experience some foot numbness or difficulty in starting and stopping due to the high altitude. The Strada’s design also ensures that many riders who previously were unable to manage a dual 26-inch recumbent will now be able to. Bacchetta claims that anyone over 5’ 6" will be able to manage the Strada. This is probably true, but I still think that 5’ 8" plus riders will be most comfortable on the bike.
Despite it’s few flaws, I can honestly say that my time with the Strada has been some of the most enjoyable that I’ve ever had with a test bike. Once we overcame a few minor production flaws that have since been corrected by Bacchetta, the bike has performed very well. I found its balance of performance and comfort to be nearly Utopian for me. If you prefer a more Easy Racers-like riding position, the Strada may not be for you, but if you like your recumbents with a more European flair or if you’re a recovering roadie who misses drafting and climbing with the peleton, you should definitely get a test ride on a Strada.
We can hardly wait for the titanium frame, dual 650C Aero!
BACCHETTA STRADA
Highs – Great balance of performance and comfort, good value
Lows – Finicky rear brake, may not work for some
MSRP - $1795
Re: Sold my Kawasaki Vulcan 900 Custom. Here's the replacement.
Posted: Tue May 20, 2008 3:42 am
by garylspolar
I changed my mind at the bike shop today. This arrives approximately June 6th:
Catrike Expedition
Posted: Tue May 20, 2008 8:17 am
by OU812
So are you out of motorcycling now? :-k
How much does one of those "trikes" cost? As much as a motorcycle? :lol:
Posted: Tue May 20, 2008 10:52 am
Does Corbin or Sargent make a seat for that? You probably need to add Hyperlights as well.
Posted: Tue May 20, 2008 3:54 pm
by garylspolar
Yup, out of motorcycling for awhile. Maybe a long while. I been spending all my time with my son, and my newly found desire to lift weights and do other healthy things. I've owned 7 different motorcycles since I was 21 (37 now), and they were all special for one reason or another... but I now find it to be a lonely hobby, as my wife does not ride with me anymore, and all my friends have sold their rides.
Yes, this trike does cost a bit. Almost $3,000 after adding a few accessories and adding sales tax. It's the most fun I've had on anything without an engine, however. I can cruise in the mid twenties, and reach speeds much higher than that on the right pavement. That was only the test ride.
The seat is incredibly comfortable, no need for a Corbin. The bicycle equivalent of Hyperlites might be a good idea, especially on the rear of the bike. This thing rides pretty low. I'll spend most of my time on trails, we have several very good ones in the Cleveland area.
Posted: Sat Jun 21, 2008 2:14 pm
by garylspolar
I did 20 miles today. Enough to break a sweat, get a feel for the trike.
I rode against the wind for the ten miles out. This seemed to slow down my sister on the upright bicycle behind me. I was laying down as I pedaled, so the air speed/direction had little or no effect on me (Just one benefit of a recumbent.) I slowed down many times for my sister to catch up, and this let me flip through the gears a number of times. This thing is smooth. I've got some high gears, providing a good top speed when I pedal hard enough. I'm actually able to make the rear wheel slip for a moment when I accelerate, although I may have hit a patch of sand/dirt on the trail. Still, it felt pretty cool.
I left my sister behind for the ten mile ride back. I decided to keep pace with a strong upright bicyclist that passed me up shortly after I began the trek home. I kept with 40 feet of him for 8 miles, averaging 18 mph, and pushed passed him several blocks before I turned onto my street. He waved, smiled, said something that I could not understand. This thing is a real head turner. I imagine half of the people are thinking, "Wow, that's cool!". The other half are thinking, "Wow, that handicapped guy can really make that tricycle move!" A few a my friends have already commented that it looks like something for "special" people.
Posted: Sun Jun 22, 2008 8:04 am
by OU812
Gary says "I am IRONMAN". I would say you are. At least somebody around here is getting the proper exercise. =D>
:badgrin:
