Removed tank & replaced, now excessive noise from fuel pump
Posted: Sun Mar 30, 2008 8:57 pm
Installed a heated grip kit today so the tank had to be removed. It was pretty empty but before reinstalling, I tipped it to the left to try and get all the gas to that side - thinking less would leak out when the lines were reconnected.
After putting everything back together it started up fine but the fuel pump is now making all kinds of noise. Kind of like when you turn the key and hear it go for a second but now it doesn't stop. Is this because the right side of the tank is empty? I didn't let it run very long - afraid of frying something. Just wondering if anyone else has encountered this and if you all think it will go away after it's filled back up?
