UK, Australia, US, EU and Japan Bikes
Posted: Fri Feb 29, 2008 12:25 am
by gaijin
Folks,
Besides riding the bike on the wrong side of the road and VIN# (last seven digits) designated as bike for Japanese market. What are the differences on R1150R that made for these countries?
Can someone clarify me on this?
Re: UK, Australia, US, EU and Japan Bikes
Posted: Fri Feb 29, 2008 2:07 am
by Rockster1150
Gaijin, I am in Oz and my handlebars are on the otherside, no just foolin' but, I know down here we don't have that black cannister located under the rear, right hand side of the bike that they have in the US. I think it is a bit of emissions gear? It is not required on our bikes downunder.
Posted: Fri Feb 29, 2008 3:04 am
by DJ Downunder
We also don't have the reflectors on the side of the front forks.
Posted: Fri Feb 29, 2008 3:32 am
by Arbee
Gaijin
Are you sure that you dont work for Suzuki?
cheers
arbee
Posted: Fri Feb 29, 2008 6:00 am
Most of the visual and environmental items have been mentioned.
One difference would be in the jumper relay used to select the right fuel map on the ECU. That I know off, there are yellow, dark brown, brown, pink or purple (my mind is slipping) and of course none.
The other would be on the short (higher numerical ratio) or long (lower numerical ratio) six gear.
Posted: Fri Feb 29, 2008 7:47 am
by gaijin
My concern issue was buying replacement parts to fit the bike if I ever needed. There are lot of things that I need to know about this bike. I just cannot assume that Japanese model would be the same as US model. If you have anything that you can think of, just put on the board.
Thank you.
boxermania wrote:Most of the visual and environmental items have been mentioned.
Posted: Fri Feb 29, 2008 8:22 am
by rdsmith3
The headlight lens should be different for riding on the other/wrong side of the road.
Posted: Fri Feb 29, 2008 8:49 am
rdsmith3 wrote:The headlight lens should be different for riding on the other/wrong side of the road.
Dunno about the "R", but on the Rockster (and GS) - the reflector inside the dipped beam unit can be rotated for each side or the road. (it's in the handbook iirc).
Posted: Fri Feb 29, 2008 9:15 am
Parts, No problem = Mondai nai my Japanese spelling is probably off..........
