Vibration R12R
Posted: Wed Jan 16, 2008 9:34 pm
by JGP
Is anyone experiencing a brief but distinct vibration around 3700. It doesn't matter which gear, it is there, go above or below and it dissapears
jgp
Posted: Thu Jan 17, 2008 12:13 am
Nope. If you are - have the dealer inspect it. That's one of the smoothest points in the RPM range. Above 4k - the vibes slightly increase incrementally with RPMs, but below 4k - smooth.
Posted: Thu Jan 17, 2008 8:29 pm
by AllanCook
What Don said. No serious vibes here.
Posted: Thu Jan 17, 2008 9:27 pm
by TWI
Idle is definitely rough. I am told it will smooth out after a few more thousand miles.
3750? No, that is OK.
R12R Vibration
Posted: Thu Jan 17, 2008 10:04 pm
by JGP
I spoke with a fellow R12R owner, who has owned multiple BMW's and is a pretty handy mechanic. His R12 also has the vibration under 4k. It is not a breaker by any means, but it is there.
Strictly at the 3600-3700 range, and can be felt in virtually every gear at that rpm. Based on Don E's input I called a dealer and have set up an appt. for next Tuesday. I advised the dealer that I just went thru the 6k service, he commented maybe I didn't get the valves and or throttle bodies tuned in just right................I wanted to ask, then the folks up at Jessup when they did the 600 mile service must have screwed up the TB and valves, because the bike has been vibrating since the day I purchased it from the orginal owner with 1,725 miles, so my doing the 6k didn't have a dam thing to do with it. The R12 runs terriric absent the 36-37 vibration.
Looking forward to your further input.
jgp
