While running the R to get stabilized gas through out the system before storage I noticed gas dripping off the right side.
Having already replaced the typical failing plastic quick dis-connects I raised the tank and found the output line from the fuel pump weeping when pressurized.
Ironically I had the same issue with my G-650GS this summer and found the OEM clip on clamp no tight allowing the hose to slide on the fitting.
I purchased a bag of screw type fuel injection hose clamps for the GS and will replace all the OEM clamps on both fuel systems this winter.
With a 18 year old Motorcycle I somewhat expect age failure, not with a 2013.
Gas line leak
Gas line leak
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
2008 Suzuki Bandit 1250
2013 BMW GS 650 Sertao
1975 Norton 850
2002 BMW R1150R
Re: Gas line leak
Those clamps don't last forever, nor do the rubber hoses. You may find that the rubber hoses have tiny cracks.
I've had the joint between the hose and the QD 'weep' a few times - I just give the clamps a good squeeze with an appropriate implement and they're find again. Never had an issue with the plastic QDs themselves.
Re: Gas line leak
Yeah the leak on the Sertao had the gas running down the left side right onto the pipe. I was JUST about get on it and ride it away and noticed it running off the swing arm. With the fuel pump and tank under the seat it would have made for a warm ride! Suffice to say I don't trust the OEM hose clamps at all.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Re: Gas line leak
Then last week I noticed a hydraulic leak on the wood splitter. Both hose clamps on the low pressure side of the pump had stripped out teeth due to vibration. Maybe I should change my screen name to”Hose Clamp” :O
https://photos.app.goo.gl/AAhXZLaW6jPghv9K7
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Re: Gas line leak
That's possibly one of the reasons they don't use them from the factory?Tundra Dweller wrote: ↑Sun Nov 29, 2020 5:14 pm Then last week I noticed a hydraulic leak on the wood splitter. Both hose clamps on the low pressure side of the pump had stripped out teeth due to vibration. Maybe I should change my screen name to”Hose Clamp” :O
Re: Gas line leak
To be fair that is not a fuel injection clamp, direct bolt to nut connection, which what I have for replacements.riceburner wrote: ↑Mon Nov 30, 2020 4:59 amThat's possibly one of the reasons they don't use them from the factory?Tundra Dweller wrote: ↑Sun Nov 29, 2020 5:14 pm Then last week I noticed a hydraulic leak on the wood splitter. Both hose clamps on the low pressure side of the pump had stripped out teeth due to vibration. Maybe I should change my screen name to”Hose Clamp” :O
Nothing is guaranteed.
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
Re: Gas line leak
Spent some time in the shop whilst watching the playoffs this weekend.
Flipping the gas tank I found the fuel hose that was leaking had a crooked clamp on the ear.
The hoses looked good though they both would spin freely. I would venture that over time as the rubber compresses the non adjustable clamps are not tight enough. Replaced with FI clamps and safety wired. More to do....thankfully.
https://photos.app.goo.gl/51DtkfX4TKZXrC3v7
1974 Kawi H-1 500
1975 Norton 850
2002 BMW R1150R
1975 Norton 850
2002 BMW R1150R
