Bleedin' clutch
Posted: Wed May 02, 2007 3:06 pm
I have 2 spare 10mm x 1.0 bleed nipples in my garage.
One of them has a pointed end (the end that screws into the caliper/bleed valve) and the other does not have the point but has a small dimple in the end as so is shorter.
I took out the grub screw in the clutch bleed valve and can see the ball bearing in the tube that prevents the fluid from coming out.
That grub screw was in TIGHT, I used the wife's hairdryer to heat the valve body and it eventually gave way with a very loud and worrying crack. I really thought I had broken something, but everything looks OK.
When I tried the bleed nipple with the pointed end, the point touches the ball bearing in the valve just before the threads start to bite, so I assume I need the nipple with the dimple in the end ?
This seems to work in reverse to a normal brake bleed.
ie I need to screw the nipple IN to get any fluid out.
Or do I screw it in far enough to push the ball back and seat the taper on the nipple and then remove it 1/4 turn to allow the fluid out ?
I think I am thinking about this too much and making it more difficult than it really is.
By now it was getting too dark to do any more tinkering and the only plastic hose I had was too large to fit the shorter nipple, so I put the grub screw back in. Will try again at the weekend.
Any one any tips ?
BTW My 'not so local' dealer parts man (see my post about home servicing) had no idea about the bleed nipple and had to go and ask a mechanic. He came back and told me he had sold the last one earlier that day.
Not sure how he managed to sell a part and then had no knowledge of what the part was later the same day.
Any one any tips ?
