2002 R1150R gas mileage
TicTac50
Donating Member #: 586
Re: 2002 R1150R gas mileage
Post by TicTac50 »
jcridge wrote:45-50MPG 2004 R1150R
When I ride on the weekends with my wife, I get 50MPG and we usually run 55-60MPH in the hills and better two lane roads.
When I ride on the weekends with my wife, it cost me more than 50 dollars per hour. :)
I think I need a better bike. :-k
Lifetime Member #586
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
f4tweet
Post by f4tweet »
I called two BMW dealers here in Southern California, and both service departments didn't think 37 mpg was bad mileage. I just wonder if there are anything out of adjustment. It does not have a chip, and the cat code plug is still in place. California gas is probably to blame. I used to get 10% worse mileage in the winter. I guess I will have to go to San Diego and back to check road mileage. 180 miles round trip. Oh well, if I have tooooooo.
02 R1150R Black
f4tweet
Post by f4tweet »
I finally was able to do a road loop and check road mileage. I did a 184.2 mile loop and got 48.783 mpg using 3.739 gallons of gas. The gas light never came on. So, I guess the problem with city driving, is my driving. I didn't think I was heavy handed, not that was I trying to be....but I was. I will keep the engine under 4K rpm and try another city tank. These bikes are very different from the old Airheads in so many ways. Thanks to everyone's help and input with this FNG question.
02 R1150R Black
bmwdave52
Post by bmwdave52 »
California gas is crap. My milage goes up when I get out of this state.
WorkinMan
Post by WorkinMan »
See... I told ya'll it was something Arnold was putting in the gas and nobody believed me.
tcm92678
Post by tcm92678 »
Hey guys, I'm new to the forum. I was wondering what octane you guys are using. I'm ridin' a '02 R1150R at the moment and the user's manual recommends using premium. I read a post here that someone was using 87 octane. Any adverse effects of using 87octane instead of the premium? Which octane will get me more mileage?
iowabeakster
Post by iowabeakster »
Use the lowest octane rating that does not result in knocking or pinging. If you can use 87 and it does not ping, great, no need to waste money on more expensive gasolines. I use 87 or 89 during cooler times and need to use premium when it is hot out.
Octane ratings will not change your milage by any noticable amount.
Buckster
Donating Member #: 543
Post by Buckster »
tcm,
Welcome to the site! I pretty much always use the mid-grade 89. In the summer, I will do every other tank with premium 92 because of pinging when its really hot.
I used to live in Naples 10 years ago and it's pretty much hot all the time. You can try all three grades and see what works best for you. The mileage should be about the same. I also use Seafoam in the winter in just about every tank and in the summer I put it in about once a month.
Enjoy your new R and watch out for the snowbirds! You will find a lot of great info on this site. Consider becoming a member and make a donation. It is money well spent for the amount of knowledge and know-how you will learn from it.
Buckster '03R
#543
Boxer
Donating Member #: 2
Post by Boxer »
As Challey said, I actually experienced better mileage on my 03 single park with spirited riding in the mountains than just cruising around. My light would consistently come on at about 167 or so. Of course the open highway with a tail wind at moderate constant speeds will get you the best (I'd get 50+ sometimes)...but that's very boring riding also.
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
An engine performs most efficiently at the peak of the torque band - optimum work for optimum inputs. For both single and dual spark models of the R1150R's that occurs around 5200-5400rpm. Try some running around without going below 3500 rpm and without shifting before 6000 rpm. If you do it right, you should see some improvement in your overall mileage performance. Of course, nothing can cure the poor mileage achieved when you stop, idle, or do tortoise starts. And among the U.S.'s 50 some blends of what we used to call gasoline, there is no accounting for the drop in efficiency using less than well formulated fuel.
f4tweet
Post by f4tweet »
I tried that and got 31 mpg combined. When I shift at 4200 and keep it around 3800 I get 37 mpg combined. ???
02 R1150R Black
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
Hi, I just bought a 02 R1150R with 30k mi. on it. My first couple of tanks of gas are running about 35/36 MPG. This is 75% city driving. Is this normal?
Normal for our west coast 10% ethanol, combined with city riding.
Not to worry.
f4tweet
Post by f4tweet »
Thanks, can't wait to go through Arizona and Colorado this summer.
02 R1150R Black
tcm92678
Post by tcm92678 »
Buckster wrote:tcm,
Thanks for the advice Buckster. Yes, I have been dodging old folks down here in FL everytime I get on Tamiami. I can't tell you how many times i've almost gotten killed by bad drivers. Anyways, I think I'll go with the 89/91 (mid) octane and stick with that. Thanks.
dcameron
Post by dcameron »
I ride mine like I stole it and continuosly get 37-38 mpg. 95% back roads up here in wine country. 8)
Evil beware, we have waffles.
'03 r1150 - the beast
'11 r1200 - Hooligan
#564
