Page 2 of 2
Re: Air filters for R1200R
Posted: Sat Apr 25, 2009 7:04 am
garydbryson wrote:Don: Just click on page 3 on this blog and it's under K&N ___GB
Maybe it's a Jersey thing but I didn't get the reference to page 3 of a blog either.
As far as the info (data) that flows freely across this list, where else can you get this kind of information about a machine that is slightly out of the mainstream. Sure some of it superfluous but I enjoy the gentlemanly exchange of conflicting ideas and no one is making anyone read this stuff or forcing them to conform to the ideas put forth here. There is always the Delete key.
While I'm here and this is an Air Filter thread (not a K&N thread) What's the deal on the BMW Blue Filter I see advertised? Is it a high performance BMW filter?
Posted: Sat Apr 25, 2009 9:33 am
by BanjoBoy
red baron wrote:Does anybody have experiences with K&N air filters for using in 08 or 07 R1200R? Besides being re-usable what are the advantages of installing these air filters?
Thanks in advance for any comments
Red Baron
Don't want to get in a urinating contest with anyone here, but I used K&N filters on an '89 FJ1200 and rode the thing for 96,000 trouble free miles. That said, the K&N filters will void your warranty, so be careful what you do.
Good luck with whatever you choose.
Posted: Sat Apr 25, 2009 11:36 am
by garydbryson
Here it is-- /Users/garybryson/Desktop/Spicer rebuttal forum.doc
Posted: Sat Apr 25, 2009 11:41 am
by garydbryson
Hi Guys: If you would go to the bottom of page 3 the K&N story is there. We are on page 1 now___GB
Posted: Sat Apr 25, 2009 1:32 pm
by garydbryson
K&N test Here it is again___GB
The filtration report generated by Mr. Arlen Spicer in 2004 (http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm) has received a great deal of attention over the past few years. The report was prepared for members of Dieselplace.com, a diesel enthusiast forum, and has circulated among other online communities. In his report, several brands of air filters were subjected to a side-by-side comparison test of their dust holding capacity, filtration efficiency, and restriction. Testand Corp. of Rhode Island offered to complete the testing for Mr. Spicer’s report at no charge. K&N is aware of Mr. Spicer’s report and its findings. The data collected from the K&N filter in Mr. Spicer’s report was unusually low and did not correlate with test data gathered by both independent and in-house testing. In 2006 we contacted Mr. Spicer and invited him to visit K&N’s headquarters in Riverside, CA to discuss the results of his report.
Mr. Spicer visited K&N in 2006, and during his visit, Mr. Spicer along with K&N employees tested a K&N air filter and its equivalent paper air filter replacement in K&N’s in-house filtration test lab. These tests were conducted using ISO 5011 protocol, which can be viewed at http://www.knfilters.com/efficiency_tes ... cedure.htm. There were differences between the test procedure used by K&N and the test procedure used in Mr. Spicer’s 2004 test, and the test results each procedure yielded. The significant differences were:
• Cumulative efficiency of the K&N filter improved from 96.8% in Mr. Spicer’s report to 98.74% in testing performed while Mr. Spicer was visiting K&N.
• Dust holding capacity of the K&N filter improved from 211 grams in Mr. Spicer’s report to 276 grams in testing performed while Mr. Spicer was visiting K&N.
• Cumulative efficiency of the paper filter decreased from 99.93% to 99.57% in the test performed at K&N while Mr. Spicer was present.
• Dust holding capacity of the paper filter increased from 573.9 grams to 792.84 grams in the test performed at K&N while Mr. Spicer was present.
• In the test performed at K&N while Mr. Spicer was present, the initial efficiency of the paper filter tested to be 98.25% and the initial efficiency of the K&N filter tested to be 98.17% (only .08% difference). Mr. Spicer’s test does not state what initial efficiencies were for any of the filters tested.
• Dust feed rate during the K&N test was 0.25 grams per cubic meter for the first 60 grams of dust fed, then 1.0 grams per cubic meter until the termination of the test. Mr. Spicer’s test used a constant dust feed rate of 1.0 grams per cubic meter for the entire test. Both dust feed methods are ISO 5011 compliant, but can yield different test results.
• Testing conducted by K&N is considered to be “constant flow” meaning the duration of the test is conducted at a set air flow rate. Mr. Spicer’s test was a “variable flow” test, meaning the test is started at an initial air flow rate which will be the maximum rate for the test, and then at specified intervals the flow will be varied by a certain percent. Both flow methods are ISO 5011 compliant, but can yield different test results.
Mr. Spicer wrote a follow-up report after his visit to K&N, and posted it on the Dieselplace.com forum. The follow-up report can be viewed at http://www.dieselplace.com/forum/showthread.php?t=66536. Mr. Spicer made certain statements in his follow-up report, which K&N feels obligated to comment on.
1. Spicer: “So, according to lab work compliant to ISO 5011, the K&N product showed performance that was significantly improved over the Testand results. So, which results are more accurate, the K&N and Southwest Research results or the results in our study? The answer to this question is not an easy one. Essentially, the results of the K&N lab results and Testand’s results are both valid and at the same time cannot be directly compared for many reasons.”
K&N: Mr. Spicer has mentioned that the K&N filter’s efficiency significantly improved over his test, but does not comment on the fact that the paper filter’s efficiency was nearly the same. Mr. Spicer also does not comment on the impact the “many reasons” can have on a test’s results, a topic which was discussed during his visit to K&N. Many of these “reasons” are “options” which are built in to the ISO 5011 test protocol for the test technician to choose, and these reasons can directly impact how a filter loads with dust.
2. Spicer: “K&N tested the filters under a much lower initial dirt feed rate of 0.25g/cu. meter for the first 60 grams of dirt and then completed the test at 1.0g/cu. meter for the remainder of the test. Testand, on the other hand, ran the entire test at 1.0g/cu. meter (9.8g/minute at 350 cu. ft/ minute). The implications of this may be speculative, but I would have to conclude that a slower initial feed rate to a clean filter could improve it’s initial efficiency%. This would lead to an improved overall filtering efficiency when compared to a filter tested under a more demanding initial feed rate as was the case with the Testand testing.”
K&N: If what Mr. Spicer claims about dust feed rates were true, why did the efficiency test results of the paper filter change very little, but the K&N change so dramatically? The answer to this lies in the options selected for each filter for Mr. Spicer’s test. K&N uses a slower dust feed rate during the initial phase of the test because a faster feed rate could prematurely plug the filter, maintaining a higher efficiency for the duration of the test. This theory is supported by comparing data from Mr. Spicer’s original test to the test performed while he was at K&N. The paper filter passed more than twice the amount of dust during the initial phase of the K&N test (at the lower feed rate) than during Mr. Spicer’s full life test at a higher feed rate.
3. Spicer: “With variable flow testing the filter experiences a continuous change in differential pressure resulting in a “capture and then release” of the dirt particles within the test media. According to an independent testing facility, variable flow testing is a more challenging test for filter medias and will commonly result in significantly lower efficiency numbers.”
K&N: The idea that varying air pressure can dislodge dust particles from an air filter is significant, but only when discussing dry paper filter media. Oiled media does a very good job of keeping captured dust in place in the filter, unless outside force is applied to knock it loose, and Mr. Spicer was able to observe this during his visit to K&N. Think of oiled media as “fly paper”. The oil is the sticky substance which traps foreign objects and holds them in place. How well would fly paper work without its stickiness? If Mr. Spicer’s theory of the effect of pressure change was valid, the efficiency of the paper filter should be significantly different in his own test (variable flow) vs. the test conducted at K&N (constant flow). But they were not.
4. Spicer: “The Testand test employed variable flow testing. The K&N test employed constant flow testing. Again, both test are ISO 5011 compliant. However, given the differences in testing methods the two results are in no way directly comparable.”
K&N: Mr. Spicer is correct; the test results for each testing method are not directly comparable. However, our experience in operating a full-time testing lab has shown us that many times the outcome we thought would happen or seemed logical, was in fact a misconception. There are many misconceptions which can be uncovered by comparing and contrasting Mr. Spicer’s original test to the test performed while he visited our lab. The overall purpose of ISO 5011 testing is not to establish a letter grade or minimum standard for air filtration efficiency, and to K&N’s knowledge such an Industry standard does not exist. ISO 5011 was written to standardize the procedure used to run the test. When two testers select different options in their testing procedures, the outcomes can be compared to determine how the selection of a particular variable affected the test outcome.
A proper question that would come up to the person who really reads this would be “why did K&N test filters using constant flow if the Spicer tests used the variable flow option”? Answer is according to the Spicer report http://home.stny.rr.com/jbplock/ISO5011/SPICER.htm on the first page under the heading Capacity and Efficiency: it states “The Capacity and Efficiency test report presents the test results of feeding an initially clean filter with PTI Course <sic> Test Dust (dirt) at a constant rate and flow.” Later in the sentence it mentions “constant airflow” again. It was not discussed until later that Testand Corp. used the variable option and we were unable to verify exactly what schedule was used.
K&N addressed these questions to Mr. Spicer in an email, since the report he wrote of his visit did not reflect the knowledge of filtration testing we thought he took home with him. Mr. Spicer acknowledged receiving our email in a post on the Dieselplace.com forum (the post can be viewed here: http://www.dieselplace.com/forum/showpo ... stcount=32) but we were unable to satisfactorily resolve the issues.
by garydbryson
Posted: Sat Apr 25, 2009 8:48 pm
OK - it appears fairly obvious in this that K&N selected test conditions that optimized the measured performance of their filter. It's playing within the rules - but is it really playing fair? We could go on at length to discuss why K&N selected a low dirt feed flow rate for the first XX amount of dirt (to load the filter up - which is when it starts filtering better, and to keep dirt from overwhelming the oiled media retention), but what I just read really proves nothing to me except that K&N can and has found testing procedures that make their filter work well. Are these real world scenerios? To me - not unless you can make certain you only see XX dirt per cubic foot of air for the first XX cubic feet of air - an unlikely scenerio on a motorbike.
What I have seen with my own beady eyeballs is oil streaming deposits downsteam of a K&N filter with some form of grit deposited in the oil. But as I've said before - it's your bike, do with it what you may. Just don't claim a big performance improvement due to a K&N filter without the dyno runs to prove it.
BTW, Gary - this isn't a blog. It's a forum - they're considerably different.. and "/Users/garybryson/Desktop/Spicer rebuttal forum.doc" refers to a document on your computer, on your desktop. We can't read that document - at least I can't.
BTW-II - what year is your R12R?
Posted: Sun Apr 26, 2009 8:16 am
Wow - that was doubly superfluous. Somehow now I feel like a victem because I run K&N filters in both my /5 and my Valkyrie.
So at risk of being censured (for thread stealing), will some one please take the time to explain what the deal is with the BMW Blue filters I see advertised.
Right now the temp is 70 heading toward 90 and my only problem is which bike is coming out of the garage. But I will need an air filter in the R1200 soon.
Posted: Sun Apr 26, 2009 9:12 am
by WILDPIG
GARY- SOME PEOPLE ARE UNWILLING TO ACKNOWLEDGE - FACTS........................... THEY GENERALLY KNOW WHO THEY ARE.
Posted: Sun Apr 26, 2009 9:51 am
mogu83 wrote:Wow - that was doubly superfluous. Somehow now I feel like a victem because I run K&N filters in both my /5 and my Valkyrie.
Harry - where are you seeing these advertised?
I don't have that quandary.. so I know which one is coming out.
Posted: Sun Apr 26, 2009 1:08 pm
by lewellen
Here's what I could find re "blue" filters for the R1200R:
http://www.wunderlichamerica.com/mm5/me ... e=R1200R-M
and
http://eire.bmwbikebits.com/categories/ ... ilters.htm
Short version: it's expensive (~$90), it's oiled-cotton fabric, it's marketed by Wunderlich, it has listed all the usual wonderful things (better breathing, more surface area), and if you combine it with a new air intake snorkel, new exhaust, et cetera, it's REALLY wonderful.
Good roads,
- Lewellen
Posted: Mon Apr 27, 2009 10:51 am
Thanks Lewellen,
I thought it was a Beemer part, but it apparently is aftermarket. I guess if I'm worried about airflow or clean air through the motor then I should just change the stock filter more often. I guess I could just stick a K&N sticker on somewhere - after all who would know.
Posted: Mon May 04, 2009 1:15 pm
by Preacher
I installed a K&N (reluctantly) on my R1200R as part of performance upgrade with full Remus and Dobeck. Can't say it really "helped" top end performance over the OEM piece. I ordinarily never use K&N's as they don't filter as well as other quality materials, and don't always flow better anyway. Probably case with this one, but not much dirt accumulated in it during the 6K miles it was on there.
Posted: Fri May 08, 2009 2:17 am
by lewellen
Preacher wrote:Probably case with this one, but not much dirt accumulated in it during the 6K miles it was on there.
Well, yeah, but if you leave the filter out entirely there's no dirt accumulation at all... :-)
Good roads,
- Lewellen
