Brake pedal height adjustment?
Re: Brake pedal height adjustment?
Towerworker- Is that the recommended way of using the iABS...front brake only and let the system apply the rear? It's been a while since I dove into the manual and honestly don't recall what if anything the book said about it. And I'm genuinely curious-
Just did a dive into the manual to see what the book says about the abs as I was curious about the *proper* way of using the system. The book really doesn't mention anything about using only the front brake other than to say that the system is integrated and that when front brake is applied the system applies a proportionate amount of rear brake. But in fairness it doesn't mention anything specifically about applying only the rear brake either.
