Hey, Rich, (no flame intendedSunbeemer wrote:I thought about doing the same thing a while ago, but realized that it would defeat the safety engineered into the shield mounting system. If the shield is too firmly attached and you hit an immovable object that jettisons you headlong over the handlebars, the shield might not give away from the mounting brackets and break off to become a scythe to your torso, thus turning an otherwise painful event into a lethal one. Just something to consider.
I have heard this argument before and have a couple of observations. The "Tall" screen 380 is completely bolted in, so if the "safety" and give way argument is valid at all, why haven't the engineers at BMW applied it to the next lower screen?
It would seem that in the event of a get off, that the touring screen gives way may be a blessing and a curse. It will be fine if your ultimate resting spot is a great big pile of soft hay, but if it is another vehicle or an abuttment I would think that the safety "afforded" by the wellnut design is worthless. It might be better for that big sheet of flexible plastic to slow you down a bit or divert your trajectory, risking the scythe effect, rather than give way so that your hurtling form can make ultimate contact with something really hard without any hindrance from the boys in Munich and as efficiently as Teutonically possible.
Finally, it must be that some brackets hold better than others, but when I had mine, more than once I looked down to see the wellnut making no contact at all with the well(read, flopping in the wind), but quite attached to the screen. I had the pleasure of watching my touring windscreen buffet and wobble in the wind. Seeing 25% of the securing mechanism fail so miserably, I waited for the rest to go and that give-way screen fly up at me. That gave me pause, at least. Seeing its failure was so infuriating that I just cannot buy that they were doing us a favor desinging it so. I replaced it before anything else and never looked back.
It is just too big a surface area to be held by something so weak. Bad design imo. A design that might work is bolts at the bottom and the wellnuts at the top. The ones at the bottom suffer the most stress and if there is anything to the safety argument, it's the ones at the top that you want to give. Just sayin'
