easternbeaver.com
marecycling
easternbeaver.com
Post by marecycling »
Just wondering if any forum members may have already installed one of these relay kits on their bike? If so, were you satisfied with the kit and end result?
The "good things" that come to those who wait, are just the "leftovers" from those who didn't!
marecycling
chime in
Was hoping "Cycle Rob" or one of the other resident gearheads(thats a compliment!)might chime in on if this addition is relevent to wiring longevity if staying with stock bulb. Any info is appreciated.
DSKYZD
Donating Member #: 187
Post by DSKYZD »
It's not you, it the subject line. With all the happytime we've had posted lately I think they're afraid to open your thread. Seems you like had one in off-topic too. One of the other mods or Doug may have zapped it.
Edit your title and see if you get any better response.
DSKYZD
JOURNEY JUNKIE #187
DG02
Post by DG02 »
I installed one of the 4 fuse, 1 unswitched setups on my new F800ST to get around the canbus electrics. They're good quality components and the service was excellent.
Dave
Member #2
Board #1
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I have been using one of their relays for several years along with a 90/100 watt headlight bulb. It works great and is easy to connect. I do not have to worry about all that current draw going through the headlight switch because it is pulling right from the battery via much heavier gauge wiring and a direct connection. Using a relay is the best way to go for a headlight upgrade, and Eastern Beaver makes it easy to do.
(I have no connection with the company.)
Bob
2002 Atlanta Blue
Lifetime Member #74
TonyT607
Double Lifer
Donating Member #: 156
Post by TonyT607 »
Two thumbs up for Jim Davis of Eastern Beaver. I ordered a fairly complex custom setup from him when I bought my R12ST in April 06. He did a great job and offered tips on installation. Top notch components and workmanship.
All done via email and diagrams.
My rig is a fused harness with relays that powers my PIAA's, GPS, XM Radio, and my ValentineOne. Jim also installed en extra set of leads for a future use. He uses Posilock and Posi-Seal connectors. All wired directly to the battery terminals (CAN BUS).
Tony
Lifetime #156
2013 K1600GT
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
Eastern Beaver is a quality vendor using high grade parts and saving us DITY's hours of head banging. I recommend.
TX2Step
Post by TX2Step »
I ordered a single H4 relay kit from him and installed it a few weeks ago. It arrived a week after I ordered it. It is made well and of high quality components. My stock 55/60 seems much brighter now.
I would not hesitate to order from Jim again.
Ron Jenson
Houston, TX
mechanic savant
Post by mechanic savant »
Another eastern beaver supporter here ,I'm using the headlight relay kit w/good results & the 411 on the site regarding bulb heat ,etc. makes it a home run all vendors should bee this good ..are ya listening out there ??
