one of the two bolts mounting the cat cracked inside the cat, so now I placed the can back for not cracking the other bolt.....
I've got to find a way for mounting my cat the right way..
just check it.....
Do you think these cracks were due to NOT having the can on?ed@r1150r wrote:I have placed my can back...![]()
one of the two bolts mounting the cat cracked inside the cat, so now I placed the can back for not cracking the other bolt.....![]()
just check it.....
well...NHighCotton wrote:Do you think these cracks were due to NOT having the can on?ed@r1150r wrote:I have placed my can back...![]()
just check it.....
Would you, or who ever the next person is to remove their can, please do this. I'm really curious about this whole weight shifting discussion:Marc Rocks 2 wrote:...
I will keep you all posted on my experience.
Will keep an eye on weight shifting, stability, fuel consumption etc.
Greetings, Marc
I wish we could have that for the driver as wellTripton wrote:you will, however still be losing weight.
Well, obviously the fridge is enough weight that it will make you go down the road leaning, but is lack of a can? Some people have put their cans back on cause they said it changed their handling, some say it makes no difference, I just want some facts. Theoretically there should be a small change, I'm just curious if it's measurable.DJ Downunder wrote:Honestly..you will not notice any difference while riding with the can off...just ask this guy..![]()
btw marc...that shiny shield is that is shown covering the connection between the cat and the chrome exhaust tip is the heat shield from the stock can..it's also the clamp that holds the can on...once it's on it looks like it's a part of the can.
Well, no... The balance of the bike is also measureable, which is what would be indicated by an actual before and after measurement.Beemeridian wrote:Only the weight would be measureable...
Ves wrote:Well, no... The balance of the bike is also measureable, which is what would be indicated by an actual before and after measurement.Beemeridian wrote:Only the weight would be measureable...
As an exaggeration, if you put a 100 lb weight on the seat, the weight of the bike changes, but the balance doesn't. But if you took that same weight and put it at the end off a three foot bar, and attached the other end of the bar to the motorcycle, the motorcycle would no longer be in balance... you would have to lean the bike away from the weight. In other words, the more weight you add or subtract and the further away it is from the center of gravity of the motorcycle (on a horizontal axis) the more the bike would have to be leaned to compensate... You would be going down the road straight but the bike would be leaning toward one side, because you've shifted the overall center of gravity. If the center of gravity shifts you have to compensate by lean... When going straight, the center of gravity always has to be centered above the contact patch of the tire.
The thing about removing the can is, it's heavy, but it's also very close to the center of gravity for the bike. So, it doesn't seem to me that there should be a noticeable lean to the bike when it's removed. That's what the measurement is for.
