Trouble shifting into first
I just got an R1150R and I absolutely love it. I don't know what I was doing wasting my time on the Sportster. One problem that I've had so far regards shifting into first from neutral. Sometimes, after sitting at a light for a while, I try to shift into first and nothing happens. There's no clicking sound at all. I usually shift into second just so I don't hold up traffic. Does anyone know what might cause this and/or what I might be doing wrong?
jred, I have had this problem too and it is something you get used to. And it changes as the bike warms up. What I do when the bike is cold is let out the clutch in neutral and then pull it in (disengage) as I press the shifter lever. Works smoothly. And, when the bike is hot I do the same thing, but wait just a hair longer (~ 1/2 second) after pulling in the clutch again before dropping into first gear to let the spinning tranny shaft slow down a bit so it engages without a clunk.
This was intially disconcerting, but now it's second nature and I don't think about it (until you mentioned it!)
Hope this works for you. The only thing that disturbs me about this trick is that if I'm sitting at a light in neutral, and I see a car coming up behind me too fast, it takes an extra split second to double-clutch and get it into gear to escape a rear-ending, so I watch my six carefully to allow enough time to do it...I hope.
Here's what I do.
Clutch in..put pressure on the gear lever..if it doesn't click in gear..slowly let out the clutch (just a little while keeping pressure on the gear lever) till it clicks in gear.
It will work every time.
I'll have to play with the clutch v shift timing technique. I just roll it forward or back a few inches and it usually pops right into gear. Almost never happens when warmed up, just when cold.
Jred, I made the same switch from an old Sportster back in November and put more miles on the 1150 in 6 weeks than I had ridden the HD in six months - enjoy the new ride!
This has happened to me, and still does once in a while. There may be some type of mechanical interlock that we are just catching the tip of. I mean, the same type of interlock that keeps the transmission from shifting more that two gears in one click of the shifter. Typically, this requires the combination of pulling in the clutch and moving the shift lever. That being the case, simply moving the clutch lever should do the trick. Whenever I'm idling in neutral, and commence shifting and it doesn't move into 1st gear, I just pull the clutch again - and it shifts into 1st just fine.
Member #1058
BMW transmission is not up-to-date with design and for some reasons they take pride in making clunky, agricultural transmission. Instead of playing with the clutch and such, just rock the bike back and forth a little bit and it'll be fine. There are a lot of things to love about BMW, but the tranny isn't one of them. Get out of the 1970s already, for God's sake!!!
- yjleesvrr
- Location: Blacksburg and Haymarket, VA/Basking Ridge, NJ
Yeah, "they all do that."
The first time I encountered it was at an intersection when the light turned green after a long red. For a split moment, I thought the transmission was broken. Then after moving the bike forward by a foot or so, the lever clicked into first.
Compared to my SV650 and (horrors!) even my Harley's, the BMW transmission leaves something to be desired in terms of feel and ease of shifting into first. From what I can tell having test-ridden the new GS a year and a half ago, the new boxer transmission is significantly better.
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
- Arbreacames
If first gear does not go in, you may be waiting too long before you shift. Once you declutch, the input shaft quickly slows down and then stops. The shaft needs to be turning for the gear to engage (when bike is stopped). On a cold transmission, you should engage the gear within a second or so. On a warm transmission, the oil is thinner and you should wait a little longer to let the shaft slow down some so that it will not clunk.
Carlos D.
motorbikemike
