speedomer/tach glass
gel9001
Post by gel9001 »
I had my tach switched out a few months ago under warranty, cause water was getting inside. Now i've got "swirl marks" on what looks like the outside of the glass on both speedo and tach. I only use soap and water to wash bike and occasionally wax the glass with Maguire's. Could this was have damaged the glass. The damage does look like its on the outside, but I guess it could be on the inside of the glass. Any thoughts?
Gene
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
Could the swirl marks just be from the wax?
Try cleaning with Meguiars clear plastic polish, then use the clear plastic cleaner for normal cleaning. I can't see why you would wax them.
Polish
http://www.meguiars.com/?pro-clear-plas ... tic-Polish
Cleaner
http://www.meguiars.com/?pro-clear-plas ... ic-Cleaner
2002 Atlanta Blue
Lifetime Member #74
gel9001
Post by gel9001 »
using wax is a quick way to get them polished. I've always done that. I've just never know wax to leave that kind of residue. Yesterday I washed the bike and couldn't get the "blemishes" out.
Gene
Packrat
Post by Packrat »
Mine has also done this. I took it to the dealer and they said it was a "3M" coating that was used to prevent fogging. There is no way to fix this except to replace the instrument. Mine is still under warranty if I ever get it there to have it swapped. The coating is inside glass of the instrument.
DSKYZD
Donating Member #: 187
Tach
Post by DSKYZD »
Did your tach look like this before you had it swapped?
(click for larger picture)
DSKYZD
JOURNEY JUNKIE #187
gel9001
Post by gel9001 »
My tach and my speedo now look alot like that. Before I had the tach swaped out it looked more clearly like water.
But again, YES, that what both speedo and tach look like now, any sugggestions?
Gene
DSKYZD
Post by DSKYZD »
If it bugs you, have your dealer swap them out. When I eventually get there that's what is supposed to happen in my case.
The pic is when the condensation has dried, it gets bad in foggy/humid conditions.
DSKYZD
JOURNEY JUNKIE #187
