Water in the gas tank...theoretically of course
Let's not ask how, but 1 unlatched gas cap + one high presure car wash = bike does not start. Stupid.
I drained 90% of the tank via siphon, now it's out in the sun hoping for expedited evaporation.
How do I fix this???
2004 R1150R Rockster tigerstripe
yeah, but..
Those big brushes feel so good on your back when you are riding through one.
problem solved
I got some plastic tubing and siphoned about 2 gallons out of the tank. I must not have gotten much water in there, because after parking it outside in the sun for 2 hours with the cap open, it started right up. Maybe just water on the spark plugs?
and, visor up!
and, visor up!
It may not have been contaminated gas. I had a problem once where the bike wouldn't start. It was towed to the dealer and taken apart. The computer claimed the wiring harness was defective. Then, all of a sudden, the symptoms changed. The computer claimed the bike was fine. It was put back together and has started fine ever since.
I had been riding is some serious rain the day before this occured. It appears a drop of water made its way inside the cable that connects to the fuel injector and shorted the electrical connection internally. Once it evaporated, it was fine. You may have forced some water down into that cable by using the high pressure wash.
Take a look at the cable that connects to the top of the left fuel injector. If water enters at the top of the strain relief, it can make its way to the connector.
I think you're right
Evaporation seemed to have fixed the problem. And by the way, by "high pressure was" I meant garden hose with a nozzle, although driving through a car wash would be a hell of a sight.
For Touchton
Both in Nashville? How have our paths not crossed? I've never seen another Rockster rider here. I'm around Vandy/Green Hills. Maybe catch up for a ride?
ProductUser
Re: For Touchton
Sounds good. I'm in Goodlettsville.renojoe wrote:Both in Nashville? How have our paths not crossed? I've never seen another Rockster rider here. I'm around Vandy/Green Hills. Maybe catch up for a ride?
