I'd like to talk to anyone who has experimented with pads and the like to minimize the grabbing.Badger wrote:The ABS system on the 50r will bring the bike to a stop quicker than even the best rider riding a non abs machine....assuming the bike is stood up. It's amazing, but the front wheel is grabby going slow and makes it easy to drop the bike......use the rear when your going slow....
As far as stopping distances and safety with or W/O ABS ? I suspect that in a straight line, on dry pavement, they'll both stop fast enough to give you nosebleed.
My reason for buying ABS had to do with the fact that I ride a lot on crowded rain soaked freeways. I was looking for a safety edge in panic stop conditions. I believe ABS gives you that.
I have read far more concerns about cost and maintenance of ABS then complaints about the operation of the system. The grabby front brake is a problem BMW should address. I suspect it's fixable because mine didn't do it until I had about 1000 miles on the bike. I do agree with you on the linked brakes. I would not like fully linked brakes. I use the rear for slow speed turns, dragging it to stablize the bike.
