Two weeks to deadline, and we've got 21 entries to date. There are some really great shots coming in.
A clarification: The photo link in the entry form should *not* be the same photo link you post in the r1150r forum. For this calendar, the forum photos are too small -- their size is capped at 1,024 pixels. The calendar photos must be cropped to at least 2,300 x 1,800 -- post the link to this size file in the form. You need two photo links: a forum link and a calendar link.
"Can't you just blow up the 1,024 to the size you need?" No, that would blur the image. You can downsize an image without degrading quality, but not up. As Joe said, the bigger the original image file, the better.
If none of this makes sense, Joe has set up a full-service link to process your original, full res photo -- the one right off the camera card:
http://www.smugmug.com/photos/guest/k2g6k3/Calendar. Simply drag and drop your image file (not your low-res forum version).
