Then I noticed that someone had a new BMW tank bag made specifically for the R1200R on E-Bay. I put in a reasonable bid and figured I would be outbid, but only two people bid and they bid real low. So I won it. I didn't even know BMW made a tank bag for the R1200R but It's a first rate piece of equipment. The map case is a little larger than the one on the RKA so putting in a full size map (I still carry a paper map) is no problem,not only does it appear water tight it's also air tight.
The way the inside is built, basically a waterproof bag with a draw string on top, I think you could throw the tank bag in a lake and the contents wouldn't get wet. The mounting system is simple and efficient, the only problem ,for me, is caused by the bar backs that make getting the front mount on a chore. Also because of the bar backs the bag doesn't tilt forward enough to easily get the gas nozzle in when filling up, but I can live with that.
http://www.maxbmwmotorcycles.com/fiche/ ... d=03252011
EXPANDED
