Pretty much as it says really. Anyone had the same problem? Sorry if this problem has been posted previously. Help / suggestions appreciated.
(Headlight and sidelights effected)
Headlight dies when turning bars to left
geordie50r
Re: Headlight dies when turning bars to left
I don't have an answer for you, but did you see this post from earlier this month? Maybe something similar?
Bike Dies When Handlebars Turned to the Right
Kristi
05 Granite Grey
05 Granite Grey
i had a similar problem with my neutral light - yep, wiring harness cable ties too tight as per previous topic/threads on this great site.geordie50r wrote:Pretty much as it says really. Anyone had the same problem? Sorry if this problem has been posted previously. Help / suggestions appreciated.
to fix, i carefully split the associated wiring harness outer sleeve & found the 1 (of the 20 odd wires inside) had torn/worn through to breaking point & just soldered in a new piece of wire, taped the join off & tucked it back into the sleeve & taped it shut - replaced some of the ties with new (looser) ones.
pete
2004 RR
pete sydney australia
2004 RR
2004 RR
