My question is if i can "transformer" my r1150gs 99 model in r1150r. I dont mean only the wheels, i mean all the front suspension system and the REAR-AXLE-DRIVE. My intention is to have the geometry of R1150R but with the confort of gs(I also wear a Touratech 41 liter fuel tank and before a few weaks i install anti-spin.
The solution to buy r1150r can not be for two reasons,First the r1150r have a servo assisstant brakes which i am not fun(in the past on my k1200s this system was big problem)
Second i like the engine which i have now he gives 83.2 hp to the back rear and he dont need even 100ml oil between the changes(i change oils every 4000 miles).
OK. First, I'm with you regarding the Integral ABS (iABS 1) servo brakes... no way I'd ever take an iABS bike to the track. Your comment "i am not fun" is exactly why I removed my Rockster's iABS system.
Second, you're correct about the R1150R and R1150GS sharing identical drivetrain. You've already got a solid motor in your GS with >80hp at the wheel (seems a reasonable dyno pull), so now you want stable handling at speed, like any good trackday rider should. My solution to the problem (and general recommendation) is a 2nd trackday-only bike, but the quest for a hot-handling GS is an honorable adventure.
Your original post here reminded me of some pics I grabbed a few years back... I'm traveling this week and can't access the files, but I think I found an online reference to the bike and its owner:
http://www.imgbox.de/show/up/Larsi/Moto ... 40955.JPG/
Yes, this bike is/was a GS. And the owner (at least in the pics I downloaded long ago) was an
avid club racer using this bike... so you know he was very familiar with high speed stability and handling.
Here's a page in which he shows the bike's transformation stages (scroll to bottom):
http://www.gs-forum.eu/showthread.php?t=50309
Note that I had not seen the finished product - with R1150R fuel tank - before tonight. Perhaps beauty is in the eye of the beholder (should coin the 'net acronym "BIITEOTB"), but I think this machine is 100% Grade A bada$$.
As the above link and post by the bike builder is less than 2 months old, perhaps you can contact "Larsi" to get some build specs.
As for R1150GS supermoto conversions, there's some info out there - example:
http://www.roesnerundrose.de/category/p ... supermoto/
And you can certainly find
LOTS of information in ADV:
http://www.advrider.com/forums/showthread.php?t=386723
There are examples out there of GS-to-R and R-to-GS conversion using combination of Telelever and Paralever parts, plus suspension/wheel/brake swaps. If I was in your shoes, a GS supermoto setup be my simplest, least expensive, and best choice.
Good luck. Show us some pics when you finish the project... especially your trackday pics.
