Hi all
My 850 has the BMW add-on tach and clock.
I was thinking of ditching the clock and fitting and 2" aftermarket oil temperature gauge... I'd rather know how hot my engine is plus I always wear a watch.
Has anyone done this?
How / where did you install the sender into the engine?
Appreciate any input on this
Cheers
Tracy
Has anyone fitted an oil temp gauge?
- TracyPrier
Re: Has anyone fitted an oil temp gauge?
Hi Tracy,
check out this http://home.mindspring.com/~jabrooks/te ... m#cyclerob
And this http://home.mindspring.com/~jabrooks/te ... m#ezcrusty
Kind regards
Kind regards
- TracyPrier
Awesome
thanks for that.
With regards as to where to put the sender, last night I was removing the sidestand (to weld a larger foot on it) and I spotted this:
http://picasaweb.google.com/lh/photo/YU ... directlink
It is up under the left hand jug.
It sure looks like an oil sender to me. Would it be the pressure sender or temp sender??
Either way I gather it contacts engine oil.
Maybe I could install a T piece and add the oil temp sender to it??
Cheers
Tracy
Cheers
Tracy
Here's some info from old message thread:
http://r1150r.org/board/viewtopic.php?f=2&t=12039
Here's where the custom VDO oil temp gauge I bought some years back ended up:
viewtopic.php?f=2&t=14174
Big questions for your R1100R (probably '95 or '96?) with instrument pods: what's the instrument diameter and allowable installation depth?
Let us know how it goes!
Hi Tracy,TracyPrier wrote:Awesomethanks for that.
Cheers
Tracy
thats the oil pressure sensor. It does not measure the oil temperature. With regards to the sensor maybe it is worthwhile looking at the R1100RS/RT/GS which had a sensor for the oil temp (indicated through the famous FID). Since the engine base of these engines is the same it might be worthwhile having a look if there is a spare available from the dealer ...
Kind regards
- TracyPrier
Right, thanks.
So it is in contact with circulating engine oil. Great, I'll install a T piece and just add the sender from the oil temp gauge (once i buy one).
Tracy
Tracy
Hi Tracy,
as I said that is the oil pressure sensor and I don't know what kind of "t-piece" you would like to install ... An electrical t-connector (will not work)? A t-piece which holds the pressure sensor and a temperature sensor? That will have to be made ... which is not an easy task plus it will stick out quite a bit.
Best regards from Germany
