an·neal (-nl)
v. an·nealed, an·neal·ing, an·neals
v.tr.
1. To subject (glass or metal) to a process of heating and slow cooling in order to toughen and reduce brittleness.
2. To strengthen or harden.
It was suggested that by annealing the crush washer its previous "softness" could be achieved and thus the washer would possibly be again the washer it once was.
If life were that simple.
Having access to a digital micrometer caliper, 3 unused crush washers and one used crush washer I decided it was time to get numbers involved.
The OD average of the new, unused crush washers, measured numerous times in both the up/down and right/left diameters was 19.81 mm (range: 19.77 - 19.86 mm)
The OD for the used CW was 19.96 or 0.76% wider
The ID average for the new unused CW's was 16.34 mm (16.32 - 16.35 mm).
The ID for the used CW was 16.26mm or 0.49% narrower.
The thickness for the new unused crush washers was very uniform: all three measured 1.37 mm thick in at least 6 spots each washer.
For the used washer there was variability of thickness from 1.26mm to 1.32 mm. In other words the used CW was, depending on the spot on the used CW anywhere from 3.6 - 8% thinner tahn new.
When I last changed the oil and tightened down the drain plug I most likely did it finger tight + 1/4 turn. There were no leaks.
So, after using the crush washer it becomes flatter, wider in OD and narrower in ID. Probably no real surprise there. It gets squished. And there may still be enough "give" in the metal to perform again as many have reported.
Will annealing restore any dimensions in addition to making the metal softer?
The jury is still out on that one, because this is what happens when you heat the CW over the gas burner on a household cooktop.
And it never turned red or yellow. It only wilted and became most certainly unusable. It must also be noted that the hemostat ( a "plastic" straight one and clicked one click only) made a very significant remarkable dent in the CW. So if you still want to try this I would lay the CW flat in a pan of some sort and NOT hold it with any pinching instrument.
My rec is NOT to attempt to anneal, especially if you do not have another CW available.
